XIGMATEK Achilles HDT-S1284C Cooler
Quicklinx: 77Q5WS00 Mfr#: CAC-SXHH4-U03
Achilles S1284C, a H.D.T. cooler, proves that it is possible to do concurrently both good-looking and performance. Its H.D.T. technology makes Achilles a remarkable performing and special fan design makes it to reach a silent level. With LED lights, transparent fan, anti-vibration rubber, Achilles S1284 offers not only friendly, reliable, easy to install, but also powerful performance for users.
XIGMATEK Achilles S1284C - processor cooler
Processor cooler
Compatibility
Socket 754, Socket 940, LGA775 Socket, Socket 939, Socket AM2
Heatsink Material
Aluminium
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Long Life Bearing
Rotation Speed
800-1500 rpm
Air Flow
61.4 cfm
Noise Level
20.6 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Heat pipe technology, white LED x4, Heat-pipe Touch Chip (HTC) technology, Pulse-width modulation (PWM) support
12 cm x 15.9 cm x 6 cm
0.66 kg
Processor cooler
12 cm
15.9 cm
6 cm
0.66 kg
Heatsink & Fan
Compatible With
Processor Compatibility
Core 2 Extreme - all speeds , Core 2 Duo - all speeds , Core 2 Quad - all speeds , Pentium D - all speeds , Celeron D - all speeds , Athlon 64 - all speeds , Athlon 64 FX - all speeds , Athlon 64 X2 - all speeds , Opteron - all speeds , Sempron - all speeds , Pentium Extreme Edition - all speeds
Heatsink Material
Aluminium
Thermal Resistance
0.14 °C/W
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Long Life Bearing
Rotation Speed
800-1500 rpm
Air Flow
61.4 cfm
Air Pressure
1.52 mm
Noise Level
20.6 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
RoHS
