Why Choose XFX PSUs?
EasyRail Technology
Don't ever worry about managing rails or running out of power before the max wattage is reached.
Modern Design
Unique industrial design like no other PSU on the market
Multi-GPU Certified (ATI/NVIDIA)
Designed for Multiple GPU gaming setups
Japanese Capacitors
Other PSUs use only some or none - XFX PSUs use ALL, meaning superb quality, longer-lasting PSUs
80Plus Bronze
Our PSUs are efficient - only 15% of the wattage drawn is lost
Clean Power
XFX PSUs are designed to deliver tight DC voltage regulation with minimum AC ripple, giving you safer, cleaner power
Five Year Warranty
XFX PSUs include a comprehensive 5 Year Warranty backed by a highly rated 5 Star Support Service
- XFX Core Edition PRO750W - power supply - 750 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.2/ EPS12V 2.91
- 80 PLUS Certification
- 80 PLUS Bronze
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 750 Watt
- Output Current
- +3.3V - 25 A / 0 A , +5V - 25 A / 0 A , +12V - 62 A / 0.6 A , -12V - 0.5 A / 0 A , +5VSB - 3 A / 0 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 6 pin PCI Express power , 2 x 8 pin PCI Express power with detachable 2 pin section , 8 x 15 pin Serial ATA power , 7 x 4 PIN internal power , 1 x 4 PIN mini-power connector
- Cooling System
- 135 mm fan
- 15 cm x 17 cm x 8.6 cm
- Environmental Standards
- ENERGY STAR
- 5-year warranty
- PSU Form Factor
- ATX
- Input Voltage
- AC 100-240 V
- Input Voltage Range
- AC 90 - 264 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 750 Watt
- Output Current
- 80 PLUS Bronze
- Cooling System
- 135 mm fan
- SLI ready, CrossFire ready, single 12V rail, ball bearing cooling fan, non-modular
- RoHS
- ENERGY STAR
- Limited warranty - 5 years
- 15 cm
- 17 cm
- 8.6 cm
