Your busy work-team needs a value-packed color device that gets the job done with the rare combination of outstanding print quality, unparalleled simplicity and day-in, day-out dependability. The WorkCentre 6505 color multifunction printer gives your important documents a powerful, colorful boost. A high print resolution makes your printed communications stand out and grab attention. Xerox exclusive toner uses particles engineered for uniform size and shape, producing superior image detail and line de?nition, and text that's sharp and clear. Pantone Color approved solid-color simulations and Xerox color correction technology ensure results that match your expectations.
Connect and go, thanks to built-in networking and seamless compatibility with mixed-user environments, including PC, Macintosh and Linux. With Xerox CentreWare IS, remote device administration is handled with ease right from your computer's browser. The device features a small footprint, which allows for easy integration within your work space, whether on your desk or in a shared location. The value-packed WorkCentre 6505 multifunction printer will save on energy and supplies costs by combining the functions of multiple devices into one.
Outstanding print quality
A high print resolution makes your printed communications stand out and grab attention. -
Advanced toner technology
Xerox exclusive toner uses particles engineered for uniform size and shape, producing superior image detail and line de?nition, and text that's sharp and clear. -
Always the right color
Pantone Color approved solid-color simulations and Xerox color correction technology ensure results that match your expectations. -
Print and go
Work quickly with high print speeds. -
More productivity for more people
Connect and go, thanks to built-in networking and seamless compatibility with mixed-user environments, including PC, Macintosh and Linux. -
Easy management
With Xerox CentreWare IS, remote device administration is handled with ease right from your computer's browser. -
A perfect ?t
The device features a small footprint, which allows for easy integration within your work space, whether on your desk or in a shared location. -
The quiet partner
Engineered for extra-quiet operation to minimize impact on busy offices. -
Consolidate and save
- Xerox WorkCentre 6505DN - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 40000 impressions
- Max Copying Speed
- Up to 23 ppm (mono) / up to 23 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG, JPEG
- Fax Resolutions
- 400 x 400 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- 140 x 140 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets, books
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, cards, labels
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 500 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail
- Power
- AC 230 V (50/60Hz)
- 43 cm x 54.4 cm x 58.4 cm
- 29.6 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Silver, ENERGY STAR Qualified
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - colour
- 40000 impressions
- Interface
- Standard Memory
- 256 MB 256 MB
- Max Supported Memory
- 768 MB 768 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Copying Features
- 2 on 1, fit to page, ID Card Copy, Clone Copy
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3
- Image Enhancement Technology
- 4-bit depth colour technology
- First Print Out Time B/W
- 12 sec
- First Print Out Time Colour
- 12 sec
Scanning
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 400 x 400 dpi
Fax Machine Features
- Broadcast Transmission
- Delayed Transmission
- Fax forwarding, e-mail function, colour faxing, LAN fax
Document & Media Handling
- Min Original Size
- 140 x 140 mm
- Max Original Size
- Original Type
- Sheets, books
- 35 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 216 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
- 250 sheets
- 500 sheets
- 1 sheet
- 150 sheets
- ADF - 35 sheets size: 140 x 140 mm - Legal (216 x 356 mm) weight: 50 g/m² - 125 g/m² , Bypass tray - 1 sheet size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Input tray - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 23 ppm (A4) - B/W , Printing: up to 23 ppm (A4) - colour
- 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
- Network Protocols
- TCP/IP
- SSL, IPsec, 802.1x, Secure Fax
- Operating System Support
- MS Windows XP, MS Windows Server 2003, Apple Mac OS X 10.5, MS Windows 7, MS Windows Vista, MS Windows Server 2008
- Software Included
- ScanSoft PaperPort, ScanSoft OmniPage, Nuance Image Retriever
- Voltage Required
- 425 Watt
- Power Consumption Standby
- 65 Watt
- Power Consumption Sleep
- 18.4 Watt
- Warm-Up Time
- 31 sec
- First Copy Out Time B/W
- 13 sec
- First Copy Out Time Colour
- 20 sec
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages
- GOST, GS, NOM, FCC Part 15 B, EMC, R&TTE, UL 60950-1, CSA C22.2 No. 60950-1-07, Section 508
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site
- 43 cm
- 54.4 cm
- 58.4 cm
- 29.6 kg
- Sound Emission
- 22 dBA (idle) / 52 dBA (operating)
- 10 °C
- 32 °C
- 10 - 85% (non-condensing)
