The WorkCentre 3315 monochrome all-in-one printers' small footprint makes these products a good fit for any home office or small business.
Automatic two-sided printing
Save time and paper with automatic double-sided printing, standard on both models. Choose the WorkCentre 3325 for two-sided scanning and copying. -
Internal Wi-Fi connectivity
The WorkCentre 3325 has built-in internal wireless connectivity. Put the printer anywhere you need it - no cables required. -
Media flexibility and quality
A variety of media sizes are supported from 8.5 x 12" legal size office paper to 3 x 5" greeting cards - at up to 1200 x 1200 dpi. -
Speed matters
Documents are ready when you are, with print speeds up to 37 pages per minute and a first-page-out time as fast as 6.5 seconds.
- Xerox WorkCentre 3315V_DN - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 50000 impressions
- Recommended Monthly Volume
- 3000 pages
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 31 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG, JPEG
- Fax Resolutions
- 300 x 300 dpi
- Original Size
- 142 x 148 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, cards, labels, recycled paper, thin paper, thick paper
- Standard Media Capacity
- 300 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, USB host
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network
- 42.4 cm x 42.2 cm x 41.7 cm
- 14.4 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - monochrome
- 50000 impressions
- 3000 pages
- Interface
- Standard Memory
- 128 MB 128 MB
- Max Supported Memory
- 384 MB 384 MB
Copying
- Copying Features
- ID Card Copy
Printing
- Up to 31 ppm
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PDF
- First Print Out Time B/W
- 6.5 sec
Scanning
- Interpolated Resolution
- 4800 x 4800 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 300 x 300 dpi
- PC Faxing
Fax Machine Features
- Speed Dialing
- 200 station(s)
- Delayed Transmission
- Fax forwarding, automatic redialing, e-mail function, colour faxing, group dialling, auto reduction
Document & Media Handling
- Min Original Size
- 142 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- 300 sheets
- 50 sheets
- 150 sheets
- ADF - 50 sheets size: 142 x 148 mm - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Bypass tray - 50 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Input tray - 250 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 31 ppm (A4) - B/W
- 1 x USB 2.0 , 1 x USB host , 1 x LAN
- Network Protocols
- SNMP, HTTPS, Bonjour
- LDAP, SSL, Apple Bonjour, IPsec, 802.1x, IP filtering, MAC address filtering
- Operating System Support
- MS Windows XP, SuSe Linux, HP-UX, MS Windows Server 2003, MS Windows Vista, Red Hat Enterprise Linux 4, MS Windows Server 2008, IBM AIX 5, Apple Mac OS X 10.5 or later, Oracle Solaris 10, Oracle Solaris 9
- 600 Watt
- Power Consumption Standby
- 50 Watt
- Power Consumption Sleep
- 8 Watt
- Warm-Up Time
- 35 sec
- First Copy Out Time B/W
- 12 sec
- Consumables Included
- 1 x toner cartridge (black)
- Supported Windows 7 Features
- Windows HD Imaging
- GOST, GS, NOM, Directive 1999/5/EC, FCC Part 68, UL 60950-1, CSA C22.2 No. 60950-1-07
- ENERGY STAR Certified
- Blue Angel Compliant
- 42.4 cm
- 42.2 cm
- 41.7 cm
- 14.4 kg
- Sound Emission
- 26 dBA (idle) / 52 dBA (operating)
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
