The VersaLink C400 and C405 revolutionise workplace productivity with next generation features and easy, instant cloud and mobile connectivity. Built for the way you work today, and ready for where you grow tomorrow – with all the flexibility and versatility your business needs to work better with minimal IT support and maximum security.
Powerful performance and peace of mind.
Right out of the box, you’ll count on your VersaLink C400 or C405 to consistently and flawlessly perform the tasks that make your business work more efficiently. From IT-free installation wizards, to step-by-step configuration options, you’re ready to go – hassle free. VersaLink devices are loaded with features and time-saving Xerox technologies designed to speed up information sharing and reduce inefficient workflows. Ensure information accuracy with Scan and Fax preview1, and do more with scanned documents with built-in optical character recognition (OCR)1. When it comes to safeguarding critical documents and data, VersaLink devices deliver a spectrum of stringent security features, including Secure Print and card authentication to control access. With the VersaLink C400 and C405, you can be confident that your documents will look their best – making you look your best – giving you the confidence you need when presenting to your customers.
Easy, efficient and entirely new.
With the customisable, capacitive 5-inch colour touchscreen, you can tap, swipe and pinch your way through tasks and functions with mobile-like ease. Preloaded Xerox® ConnectKey® Apps help optimise office efficiency, and on-screen access to the extensive Xerox® App Gallery provides expanded functionality – like the
Xerox® Easy Translator Service app1, which quickly translates scanned documents into numerous languages. Speed through tasks by saving common settings as presets for simple, single-touch job setup. With Simple ID, individual users and groups enter a user ID and password once, and then enjoy fast, secure, easy ccess to task-specific presets and commonly used apps on a personalised home screen.
Freedom, and appbased functionality.
The VersaLink C400 Colour Printer and VersaLink C405 Colour Multifunction Printer gives you the freedom to work where and how you want – with out-of-the-box direct connectivity to Google Drive™, Microsoft® OneDrive® and DropBox™, and access to additional options through the Xerox® App Gallery. The ability to connect and print from multiple devices is key for today’s worker, and VersaLink devices meet the challenge with optional Wi-Fi and Wi-Fi Direct, plus Apple® AirPrint®, Google Cloud Print™, Xerox® Print Service Plug-in for Android™, Near Field Communication (NFC) Tap-to-Pair and Mopria®.
*1 VersaLink C405 only.
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
CQ2Y 040475 Condition: Customer return - item has been opened but is in excellent condition |
£74.32 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
