The Xerox Travel Scanner 150 is lightweight, smaller than a three hole punch and needs no AC outlet. Just connect the USB cable to your laptop, insert a document and you're scanning. And not just scanning, but scanning to popular and productive destinations such as email and Word, local/network/cloud storage or Microsoft SharePoint.
Efficient scanning capability
With a color depth of 24-bit (16.7 million colors) and grayscale depth of 8-bit (256 gray levels), the Travel Scanner 150 delivers rich, detailed images for all your scanning needs. Its ability to handle up to 165 scans per day makes it a reliable choice for frequent use. -
Compact and portable design
Designed with portability in mind, the Travel Scanner 150 features a compact form factor that makes it easy to carry in a briefcase or laptop bag. Its USB-powered operation eliminates the need for an external power source, allowing for efficient scanning anywhere. -
Advanced imaging features
Equipped with Visioneer Acuity Technology, Auto Crop, Auto Straighten, and auto brightness features, the Travel Scanner 150 ensures your scans are clear, straight, and correctly exposed every time. These smart features simplify the scanning process, delivering professional results with minimal effort.
- Xerox Travel Scanner 150 - sheetfed scanner - portable - USB 2.0
- Sheetfed scanner - portable
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Light Source
- RGB LED array
- Max Supported Document Size
- Legal (216 x 356 mm)
- Input Type
- Grayscale / Color Depth
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi
- Max Document Size
- 216 mm x 356 mm
- Supported Document Type
- Plain paper, business card, photo
- Document Feeder Type
- Manual
- Duty Cycle
- 165 scans per day
- System Requirements
- Microsoft Windows Vista / XP / 7 / 8
- 29.7 cm x 5.1 cm x 3.8 cm
- 340 g
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 24-bit (16.7 million colours)
- 600 dpi
- Bulb / Light Source Type
- RGB LED array
- Duty Cycle
- 165 scans per day
- Scanner Speed Details
- 10 sec/scan - black & white - Letter - 200 dpi , 10 sec/scan - colour - Letter - 150 dpi
- Scanner Features
- Powered by USB port, Auto Crop, AutoLaunch Technology, Auto Straighten, auto brightness, Visioneer Acuity Technology
- TWAIN, WIA
Media Handling
- Max Document Size
- 216 mm x 356 mm
- Manual
- Interfaces Details
- USB 2.0
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Software Included
- Presto! BizCard, Nuance PaperPort, Visioneer OneTouch, Nuance OmniPage, Visioneer Acuity, Nuance PDF Converter, Visioneer DriverPLUS
- OS Required
- System Requirements Details
- Windows XP/Vista/7/8 - Pentium 4 RAM 2 GB - HD 350 MB
- 29.7 cm
- 5.1 cm
- 3.8 cm
- 340 g
