Xerox DocuMate 6440 A4 Colour Document Scanner
Quicklinx: CB0TWS00 Mfr#: 100N03218
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 241 x 2997 mm
Interface: USB 2.0
Compatibility: PC
£381.10 ex VAT
£457.32 inc VAT
Information is the lifeblood of every business. In today's digital world, it's important to be able to manage paper documents and unlock business-critical data stored in documents. The Xerox DocuMate 6440 is a fast and user-friendly scanner. With its advanced paper handling technology, integrated image enhancing software and a small footprint, the DocuMate 6440 is packed with features that will change how you look at and manage paper documents and information.
  • Effective paper management
  • No industry left behind
    Its versatility, combined with advanced features makes the DocuMate 6440 an attractive solution for banking, education, energy, financial, government, healthcare and manufacturing industries. Plastic ID and insurance cards, as well as paper documents, can be scanned through the automatic document feeder (ADF).
  • Automated workflow with one easy touch
    The DocuMate 6440 is powered by Visioneer OneTouch technology to scan documents instantly to one of nine preset, yet completely configurable destinations. Visioneer OneTouch takes control of your document management workflows and scans in data using the optimal settings for resolution, color, duplex, auto-crop, auto-straighten and file format, and then delivers it to virtually any application, folder or device at the touch of a button.
Xerox DocuMate 6440 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
CCD
Light Source
LED
Max Supported Document Size
241 x 2997 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi
Interpolated Resolution
1200 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
241 mm x 2997 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card, photo
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
6000 scans per day
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Windows 10
31.6 cm x 16.8 cm x 19.1 cm
4.2 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
241 x 2997 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi
1200 dpi
Automatic Duplexing
CCD
Bulb / Light Source Type
LED
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Duty Cycle
6000 scans per day
Scanner Speed Details
60 ppm - black & white - 200 dpi , 60 ppm - colour - 200 dpi , 40 ppm - black & white - 300 dpi , 40 ppm - colour - 300 dpi
Scan File Formats
PDF
TWAIN, ISIS, WIA
Media Handling
Max Document Size
241 mm x 2997 mm
Supported Document Size Details
ADF - up to 241 x 2997 mm
Automatic
80 sheets
Interfaces Details
USB 2.0
1 x USB cable
ENERGY STAR Certified
Software Included
Drivers & Utilities, Nuance PaperPort, Visioneer OneTouch, Visioneer Acuity, Nuance Power PDF, Nuance OmniPage Ultimate
System Requirements Details
Windows XP/Vista/7/8/10 - Pentium 4 RAM 2 GB - HD 350 MB (USB)
31.6 cm
16.8 cm
19.1 cm
4.2 kg
Interface: USB 2.0
Compatibility: PC
Brand: Xerox
