The Phaser 7100 color printer excels at producing exceptional detail and clarity on a wide variety of media - including oversize paper - providing the capabilities you need to ensure every important print job makes a strong impression.
- Xerox Phaser 7100V_DN - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 44 kg
- Media Size Class
- A3/Ledger
- Max Media Size
- A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm)
- Min Media Size (Custom)
- 75 mm x 98 mm
- Max Media Size (Custom)
- 297 mm x 432 mm
- Print Speed
- Up to 30 ppm - B/W , Up to 30 ppm - colour
- Max Resolution (B&W)
- 1200 dpi
- Max Resolution (Colour)
- 1200 dpi
- Automatic Duplexing
- Interface
- USB, LAN
- Processor
- 667 MHz
- RAM Installed (Max)
- 1 GB (2 GB)
- Language Simulation
- PCL 5C, PostScript 3, PCL 6, PDF, XPS
- Media Type
- Plain paper
- Total Media Capacity
- 400 sheets
- Media Handling
- 150-sheet bypass tray, 250-sheet input tray
- Monthly Duty Cycle (max)
- 52000 pages
- Recommended Monthly Volume
- 8000 pages
- Networking
- Print server - Ethernet, Fast Ethernet
- System Requirements
- UNIX, Linux, Microsoft Windows XP or later, Apple MacOS X 10.5 or later
- 1-year warranty
- 49.95 cm x 53.8 cm x 40.6 cm
- Printer Type
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 1200 dpi
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 9 sec
- First Print Out Time Colour
- 11 sec
- Fonts Included
- 82 x PCL , 136 x PostScript
- Colour Management Features
- PANTONE Digital Color
- Media Handling
- Processor
- 667 MHz
RAM
- 1 GB / 2 GB (max)
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A3/Ledger
- Max Media Size
- 75 mm x 98 mm
- 297 mm x 432 mm
- Media Sizes
- A5 (148 x 210 mm), A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm), 75 x 98 mm
- Media Weight
- 60 g/m² - 216 g/m²
- 400 sheets
- Media Feeders
- 1 x automatic - 150 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 216 g/m² , 1 x automatic - 250 sheets - 297 x 432 mm weight: 60 g/m² - 216 g/m²
- Max Media Capacity
- 2050 sheets
- Output Trays Capacity
- 250 sheets
Duty Cycle
- 52000 pages
- 8000 pages
- Networking
- Print server
- Data Link Protocol
- TCP/IP, Bonjour
- Remote Management Protocol
- SNMP 3, HTTPS
- Secure Print, SSL, IPsec, 802.1x, IP filtering
- IEEE 802.1x
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- EMC, UL 60950-1, CSA C22.2 No. 60950-1-07, FCC Part 15 A, Directive 2004/108/EC, EN 60950-1 Second Edition, Directive 2006/95/EC
- Power Device
- Power supply - internal
- 600 Watt
- Power Consumption Stand by / Sleep
- 75 Watt
- Software Included
- Drivers & Utilities, Print WebJet Admin plug-in, Xerox CentreWare Web, Xerox Job Accounting, Xerox Global Print Driver, Xerox CentreWare Internet Services, Xerox Mobile Express Driver
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site
- 5 °C
- 32 °C
- 15 - 85% (non-condensing)
- 49.95 cm
- 53.8 cm
- 40.6 cm
- 44 kg
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.67 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.82 |
