The Xerox Phaser 5550DN laser printer means serious business for any office with diverse and high-volume print demands because it combines high productivity with low cost to own and operate. Large workgroups will get Xerox quality, reliability, and performance in a printer that can print at up to 50 ppm and hold up to 4,100 sheets.
- Xerox Phaser 5550DN - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 41 kg
- Media Size Class
- A3/Ledger
- Max Media Size
- A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm)
- Min Media Size (Custom)
- 89 mm x 98 mm
- Max Media Size (Custom)
- 297 mm x 432 mm
- Print Speed
- Up to 50 ppm - max speed - ANSI A (Letter) (216 x 279 mm) , Up to 50 ppm - max speed - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Automatic Duplexing
- Interface
- Parallel, USB, Gigabit LAN
- Processor
- 500 MHz
- RAM Installed (Max)
- 256 MB (1 GB)
- Card Reader
- Language Simulation
- PCL 5E, PostScript 3, PCL 6
- Media Type
- Envelopes, transparencies, labels, plain paper, business cards, heavy-weight paper, cards, bond paper, recycled paper, cover paper, plain paper tabs, coated paper
- Total Media Capacity
- 1100 sheets
- Media Handling
- 2x 500-sheet input trays, 100-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 300000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet, EtherTalk - integrated
- System Requirements
- Red Hat Linux 9, SunSoft Solaris 2.5.1, HP-UX 10.20 or later, SCO Unix, SunSoft Solaris 2.6 or later, Novell NetWare 5.x, IBM AIX 5.1, HP-UX 11i, Novell NetWare 4.x or later, SunSoft Solaris 9, Apple MacOS X 10.2 or later, Microsoft Windows Server 2003, Novell NetWare 6.5, SunSoft Solaris 10, SuSE Linux 9.x, HP-UX 11, SuSE Linux 10.0, Red Hat Fedora Core 5, Microsoft Windows Vista / 2000 / XP
- 1-year warranty
- 64 cm x 52.5 cm x 49.8 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6.5 sec
- Fonts Included
- 83 x PCL , 139 x PostScript
- Media Handling
- Processor
- 500 MHz
RAM
- 256 MB / 1 GB (max)
- Slots Qty
- 2
- Empty Slots
- 1
Card Reader
- Card reader
- Supported Flash Memory Cards
- SIM card
Media Handling
- Media Type
- Media Size Class
- A3/Ledger
- Max Media Size
- 89 mm x 98 mm
- 297 mm x 432 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm), 297 x 432 mm, 140 x 182 mm, 89 x 98 mm
- Media Weight
- 60 g/m² - 215 g/m²
- 1100 sheets
- Media Feeders
- 1 x automatic - 100 sheets - 297 x 432 mm weight: 60 g/m² - 215 g/m² , 1 x automatic - 500 sheets - 297 x 432 mm weight: 60 g/m² - 105 g/m² , 1 x automatic - 500 sheets - 297 x 432 mm weight: 60 g/m² - 215 g/m² , 2 x automatic (optional) - 500 sheets - 297 x 432 mm weight: 60 g/m² - 215 g/m² , 1 x automatic (optional) - 2000 sheets - 216 x 297 mm weight: 60 g/m² - 215 g/m² , 1 x automatic (optional) - 100 envelopes - 162 x 241 mm
- Max Media Capacity
- 4100 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 300000 pages
- Networking
- Print server - integrated
- Data Link Protocol
- TCP/IP, IP/IPX, LPR/LPD, FTP, RAW, BOOTP, DHCP, DNS, SLP
- Remote Management Protocol
- SNMP 1, SNMP 2, SNMP 3, IPP, HTTP, HTTPS
- 802.1x
- Expansion Bays
- 1 (total) / 1 (free) x internal
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x parallel - 36 PIN Centronics , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 35000 pages , 1 x drum - up to 60000 pages
- FCC Class A certified, IEC 825-1/EN 60825-1 class 1, EN55024, EN55022 Class A, EMC, FCC Part 15, ICES-003 Class A, RoHS, Laser Class 1, UL 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03, WEEE, FDA
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 900 Watt
- Power Consumption Stand by / Sleep
- 105 Watt
- Software Included
- Driver, Xerox CentreWare IS Embedded Web Server, Xerox CentreWare Printer Management for Microsoft, Xerox CentreWare Printer Management for Novell, Xerox CentreWare Printer Management for UNIX, Xerox NDPS Gateway, Xerox Walk-Up Printer Driver, Xerox CentreWare Web, Xerox MaiLinX Alerts, Xerox PhaserSMART, Xerox PrintingScout, Xerox Usage Analysis Tool, Xerox Job Accounting, Xerox Installer, Xerox CentreWare for HP OpenView, Xerox CentreWare for Tivoli NetView, Xerox CentreWare for Unicenter TNG
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site
- 5 °C
- 32 °C
- 15 - 85%
- Sound Emission (Idle)
- 22 dB
- Sound Emission (Operating)
- 54 dB
- 64 cm
- 52.5 cm
- 49.8 cm
- 41 kg
