The convenient, value-packed Phaser 3320 printer delivers reliable, economical performance where you need it, helping you stay focused on what matters most: growing your business.
Standard duplexing
Highly efficient, no-hassle two-sided printing can cut your paper consumption and cost in half. -
Outstanding performance
A fast print speed of up to 37 ppm and a first-page-out time as fast as 6.5 seconds mean your documents are always ready when you need them. -
Go wireless
The Phaser 3320 comes standard with internal Wi-Fi connectivity, giving you the freedom to choose the device that's right for you, and put it right where you need it. -
Stay secure
Keep your sensitive documents away from unintended recipients with the security features, including IPsec, SNMPv3, IP filtering and secure print. -
Productivity where you need it
It features a small footprint, which allows for easy integration within your work space, whether on your desk or in a shared location. -
Economical efficiency
Available high-capacity print cartridges reduce your total cost of ownership and demand less frequent replacement. -
Easy management
With Xerox CenterWare IS, remote device administration is handled with ease right from your computer's browser.
- Xerox Phaser 3320V_DNI - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 9.9 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 35 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Automatic Duplexing
- Interface
- USB, Gigabit LAN, Wi-Fi
- Processor
- 600 MHz
- RAM Installed (Max)
- 128 MB (384 MB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, PDF
- Media Type
- Plain paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 80000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11 - internal
- Printer Features
- Fit-to-page
- System Requirements
- HP-UX, SuSe Linux, Microsoft Windows XP, SunSoft Solaris 9, Microsoft Windows Server 2003, Microsoft Windows 7, Red Hat Enterprise Linux 4, Red Hat Fedora Core, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008, Oracle Solaris 10, IBM AIX 5
- 36.6 cm x 36.8 cm x 25.7 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 6.5 sec
- Printer Features
- Fit-to-page
- Media Handling
- Processor
- 600 MHz
RAM
- 128 MB / 384 MB (max)
Media Handling
- Media Type
- Plain paper
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- Media Weight
- 60 g/m² - 163 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m²
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 80000 pages
- Networking
- Print server - internal
- Data Link Protocol
- Bonjour
- Remote Management Protocol
- SNMP 3, HTTPS
- LDAP, SSL, IPsec, 802.1x, IP filtering, MAC address filtering
- Expansion Slots
- Memory
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black)
- GOST, GS, NOM, FCC Part 68, EMC, UL 60950-1, CSA C22.2 No. 60950-1-07
- Power Device
- Power supply - internal
- 420 Watt
- Power Consumption Stand by / Sleep
- 48 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- 10 °C
- 32 °C
- 20 - 80% (non-condensing)
- Sound Emission (Idle)
- 26 dBA
- Sound Emission (Operating)
- 52 dBA
- 36.6 cm
- 36.8 cm
- 25.7 cm
- 9.9 kg
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.16 |
