Xerox Phaser 3260V_DNI Mono Laser Printer
Quicklinx: 9X6YWS00 Mfr#: 3260V_DNI
  • Windows 8 (32/64 bits)
Achieve your objectives. The Phaser 3260 printer and is compact, yet extremely powerful. It is designed to support either a single user or a small team. The Phaser 3260 features fast, automatic two-sided printing with crisp, clear text and graphics.
  • Budget friendly
    Keep your costs down with fast, reliable printing for a single user or small team.
  • Count on it
    Keep intervention to a minimum with long lasting, easy to replace cartridges and reliable operation that handles every job with ease.
  • Print efficiently
    Split supplies mean you replace only what you use - so you get the most out of every print cartridge.
  • Quick print
    A print speed of up to 28 ppm and a rapid first page-out time as fast as 8.5 seconds, enable you to spend less time at the device and more time focusing on your business.
  • Save more than money
    Standard, automatic two-sided printing saves valuable time and paper, while Power Save and Toner Save modes, and the Earth Smart print driver, let you choose to spend less on electricity and consumables.
  • Visual impact
    Printing at 4800 x 600 dpi enhanced image quality, together with PCL and PostScript emulations, ensures consistently clear text and sharp graphics.
  • Wi-Fi Direct
    Now mobile phones, tablets and laptop computers can make a secure connection directly to the printer or multifunction printer even if you don't have an existing wireless network.
  • It's not complicated
    The Xerox Easy Wireless Setup helps you connect quickly and easily to your Wi-Fi network.
  • Easy to reach
    These devices, featuring quiet operation, built-in wireless networking and compact designs, fit exactly where you need them to be most productive.
Xerox Phaser 3260V_DNI - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
7.6 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 29 ppm - B/W , Up to 28 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
4800 x 600 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
600 MHz
RAM Installed (Max)
256 MB
Language Simulation
PCL 5E, PostScript 3, PCL 6
Media Type
Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, card stock
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, 1-sheet multipurpose tray
Monthly Duty Cycle (max)
30000 pages
Print server
Printer Features
Fit-to-page
HP-UX 11.0, Microsoft Windows 2000, IBM AIX 5.1, HP-UX 11i v2, HP-UX 11i v1, openSUSE 11.0, SunSoft Solaris x86 10, SunSoft Solaris x64 9, SUSE Linux Enterprise Desktop 11, SUSE Linux Enterprise Desktop 10, HP-UX 11i v3, Red Hat Enterprise Linux 5, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Ubuntu 10.04, Red Hat Enterprise Linux 6, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Red Hat Fedora 11, IBM AIX 7.1, SunSoft Solaris x86 11, Debian Linux 5.0, Windows 8 (32/64 bits), Apple MacOS X 10.5 - 10.9, openSUSE 12.3, Linux Mint 13, Ubuntu 13.04, Red Hat Fedora 19
36.8 cm x 33.5 cm x 21.4 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Wired
AirPrint Enabled
4800 x 600 dpi
Automatic Duplexing
PostScript Support
Included
First Print Out Time B/W
8.5 sec
Language Simulation
Fonts Included
136 x PostScript , 111 x PCL
Printer Features
Fit-to-page
Media Handling
600 MHz
RAM
RAM Installed (Max)
256 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm)
Media Weight
60 g/m² - 220 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Output Trays Capacity
150 sheets
Duty Cycle
30000 pages
Print server
Remote Management Protocol
SNMP 3, HTTPS
Security Protocols & Features
SSL, WPA2, IPsec, 802.1x
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
1 x USB cable
Consumables Included
1 x toner cartridge (black) - up to 1500 pages ISO/IEC 19752 , 1 x drum - up to 10000 pages
EN55024, EN55022 Class B, ICES-003 Class B, FCC Part 15 B, RoHS, UL 60950-1, WEEE, FDA, EN 60825-1, Directive 2004/108/EC, EN 60950-1 Second Edition, Directive 2006/95/EC, CSA C22.2 No. 60950-1-07 Second Edition, Directive 2012/19/EU, Directive 2011/65/EU
Power supply - internal
Frequency Required
50/60 Hz
417 Watt
Power Consumption Stand by
46 Watt
Power Consumption Sleep
2 Watt
Software Included
Drivers & Utilities
Environmental Standards
Blue Angel
ENERGY STAR
Limited warranty - 2 years - pick-up and return
10 °C
32 °C
20 - 80% (non-condensing)
Sound Emission (Idle)
30 dBA
Sound Emission (Operating)
53 dBA
36.8 cm
33.5 cm
21.4 cm
7.6 kg
Ink (2)
9X6Y Xerox Black High Capacity Toner Cartridge In Stock £95.47
9X6Y Xerox Standard Capacity Black Toner Cartridge (1500 Pages) In Stock £62.40
Other bundles (1)
9X6Y C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.80
