Whether supporting one user or a small work team, the Phaser 3250DN laser printer offers the ultimate combination of fast printing, office-friendly convenience and unbeatable overall value in a compact, space-saving design.
The Phaser 3250DN configuration includes CenterWare IS, an embedded web server that allows users and IT personnel to perform detailed status checks on the system and consumables, administer system settings, and manage access and accounting controls via any standard web browser. The Phaser 3250DN laser printer supports many common network protocols including TCP / IP, HTTP 1.1, SNMP 1-2 and EtherTalk.
Phaser 3250
This powerful little printer is ready to support a single user or a small workgroup with fast, automatic two-sided printing, office-friendly convenience and outstanding overall value. -
Quick Facts
•Two-sided printing standard on all configurations • First-page-out time of as fast as 8.5 seconds • Maximum paper size: A4 • Standard paper capacity: 250 sheet tray plus one-sheet multipurpose tray • Maximum paper capacity: 501 sheets • Up to 1200 image quality • 400 MHz processor • 32 MB memory standard, 160 MB maximum • Windows (including Vista), Mac, and Linux compatible • One-year On-site warranty • Maximum duty cycle of 30,000 pages per month • Minimum dimensions (w x d x h): 364 x 370 x 239 mm • What comes in the box: •Print cartridge (capacity: 2,000 pages1) • Power cord • USB cable • Software and documentation • NOTE: Some contents may be shipped separately -
Value Features
•Get your work done fast with print speeds up to 28 ppm and as fast as 8.5 seconds to first page • Automatic two-sided printing is standard on all configurations, saving you time and paper • Network connectivity on Phaser 3250/DN helps more users get more work done • Toner save mode extends the life of your cartridge and reduces your cost per page without a significant reduction in print quality • Power save mode helps you spend less on electricity • N-up feature prints multiple pages on a single sheet, saving paper, ink, and money -
Convenience Features
•Small footprint can fit almost anywhere you need it • Up to 160 MB of memory enhances your performance, especially when printing large files • Optional 250-sheet tray increases your paper capacity to 500 sheets and allows the Phaser 3250 to print with fewer interruptions • Media flexibility lets you print on custom paper sizes, media types and weights to help you meet your diverse printing needs • PC, Mac, and Linux drivers let you easily print in mixed environments • Booklet printing feature automatically arranges your documents into booklet format -
Quality Features
•1200 image quality resolution delivers exceptional print quality without slowing down the powerful performance of the Phaser 3250 • Powerful 400 MHz processor prints even complex graphics quickly and accurately • Adobe PostScript 3 compatibility (on Phaser 3250VDN model only) and PCL 6 emulation ensure your print jobs are always accurate • High duty cycle of 30,000 pages per month ensures you can regularly handle big print volumes with ease • One-year on-site warranty gets you back to work fast if problems arise 1 Average standard pages. Declared Yield in accordance with ISO/IEC 19752. Yield will vary based on image, area coverage and print mode.
- Xerox Phaser 3250DN - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 11.9 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 30 ppm - max speed - ANSI A (Letter) (216 x 279 mm) , Up to 28 ppm - max speed - A4 (210 x 297 mm) , Up to 14.5 ppm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 14 ppm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Image Enhancement Technology
- 1200 IQ
- Automatic Duplexing
- Interface
- USB, LAN
- Processor
- 400 MHz
- RAM Installed (Max)
- 32 MB (160 MB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, IBM ProPrinter, Windows GDI driver, EPSON
- Media Type
- Envelopes, transparencies, labels, plain paper, cards, bond paper, recycled paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 30000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, EtherTalk - internal
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows Vista, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Apple MacOS X 10.3 - 10.5, Mandrake Linux 9.2 - 10.1, Red Hat Fedora Core 1 - 4, Red Hat Linux 8 - 9, SuSE Linux 8.2 - 9.2
- Microsoft Certification
- Works with Windows Vista
- 1-year warranty
- 36.4 cm x 36.9 cm x 23.9 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 1200 dpi
- 1200 IQ
- PostScript Support
- Standard
- First Print Out Time B/W
- 8.5 sec
- Fonts Included
- 1 x bitmapped , 45 x scalable , 136 x PostScript
- Media Handling
- Processor
- 400 MHz
RAM
- 32 MB / 160 MB (max)
- Slots Qty
- 1
- Empty Slots
- 1
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), 76 x 127 mm, Oficio (216 x 343 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 250 sheets
- Media Feeders
- 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x automatic (optional) - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m²
- Max Media Capacity
- 500 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 30000 pages
- Networking
- Print server - internal
- Data Link Protocol
- TCP/IP, BOOTP, DHCP
- Remote Management Protocol
- SNMP 1, SNMP 2, HTTP
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Cables Included
- 1 x USB cable
- Consumables Included
- 1 x toner cartridge (black) - up to 2000 pages
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- EMC, UL 60950-1, CSA C22.2 No. 60950-1-03
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 400 Watt
- Power Consumption Stand by / Sleep
- 70 Watt
- Software Included
- Driver, Xerox CentreWare IS Embedded Web Server, Xerox Installer, Xerox Printer Setting Utility
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - replacement - 1 year - shipment - response time: next day
- 10 °C
- 32 °C
- 20 - 80%
- Sound Emission (Idle)
- 29 dB
- Sound Emission (Operating)
- 54 dB
- 36.4 cm
- 36.9 cm
- 23.9 cm
- 11.9 kg
