A truly mobile device in every sense of the word, Xerox Mobile Scanner gives you the power to take the information in your hand, right now, and share it with the world in seconds. The Xerox Mobile Scanner needs no cables or computer to operate. It talks to your PC, Android, Mac, iPhone, iPad, iPod touch, or the cloud over Wi-Fi. It lets you send your document anywhere your mobile device will take you and it is as simple as the gesture of handing someone a piece of paper.
Efficient scanning
Equipped with a Contact Image Sensor (CIS) and LED lamp, this portable scanner ensures efficient, high-quality color scanning of both photos and plain paper documents. -
Convenient portability
Designed as a sheetfed scanner with a compact form factor, it offers convenience for scanning on-the-go, powered by a battery that recharges in just 4 hr. -
Versatile connectivity
Includes a USB cable for easy connection to PCs, complemented by an external power adapter for flexible power options when mobile.
- Xerox Mobile Scanner - sheetfed scanner - portable - USB 2.0, Wi-Fi(n)
- Sheetfed scanner - portable
- Interface Type
- USB 2.0, Wi-Fi(n)
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Light Source
- LED
- Additional Functions
- Scan to flash card
- Max Supported Document Size
- 216 x 297 mm
- Input Type
- Optical Resolution
- 300 dpi
- Scan Speed
- 10 sec / page
- Supported Document Type
- Plain paper, plastic card, photo
- Battery
- 1
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5 or later, Microsoft Windows XP SP3
- 7 cm x 29.3 cm x 5.1 cm
- 0.64 kg
- Interface Type
- USB 2.0, Wi-Fi(n)
- 216 x 297 mm
Scanner
- Input Type
- 300 dpi
- Bulb / Light Source Type
- LED
- Scan Speed
- 10 sec / page
- Scanner Features
- Scan to portable USB drive
Media Handling
- Supported Flash Memory Cards
- SDHC Memory Card
- Interfaces Details
- USB 2.0 - Type A , USB 2.0 - Mini-B
- Included Accessories
- White calibration sheet, carrying case, cleaning sheet, 4 GB Eye-Fi card
- Cables Included
- 1 x USB cable
- Power Device
- External power adapter
- Battery Installed
- 1
- Run Time (Up To)
- 300 pages
- Recharge Time
- 4 hours
- Software Included
- Nuance PaperPort, Nuance OmniPage, Xerox Mobile Scanner PC Connect, Xerox Mobile Scanner Mac Connect
- OS Required
- 7 cm
- 29.3 cm
- 5.1 cm
- 0.64 kg
