There are super powers packed in this small scanner. Capable of scanning a variety of documents, including long, small, thick and thin sheets, the DocuMate 5445 will greatly boost the efficiency of your office. Conveniently small enough to fit on a desktop, the scanner is designed to quickly scan ID cards and other documents, enabling real-time information sharing to provide fast, accurate customer service. The scanner has a convenient interface that allows the user to simply insert their document and press one button on the front panel to initiate scanning and automatically email, print, convert or share their document. Visioneer OneTouch provides scanning presets at the optimal resolution, color depth, file format and paper size for common scanning tasks, which can also be easily changed at any time.
Another unique feature of the DocuMate 5445 is the paper feed rollers. The rollers rotate independently left and right to reduce document skewing during scanning. In addition, the active double-feed prevention roller reverses rotation the instant that the leading document leaves the paper feed section to prevent the double-feeding of documents that are simply stuck together. However, there are documents for which scanning should not be stopped even when double-feeding is detected. Those include envelopes and documents with sticky notes attached. When the DocuMate 5445 pauses at one of these documents, scanning is easily resumed with the touch of a button.
Small, highly versatile scanning solution for any business
There is super power packed in this small scanner. Capable of scanning a variety of documents, including long, small, thick and thin sheets, the Xerox DocuMate 5445 will greatly boost the efficiency of your office. Conveniently small enough to fit on the reception desk of a medical office or bank, the scanner is designed to quickly scan customer or patient ID cards and other documents, enabling real-time information sharing to provide fast, accurate customer service. The scanners have a convenient interface that allows the user to simply insert their document and press one button on the front panel to initiate scanning and automatically email, print, convert or share their document. Visioneer OneTouch provides scanning presets at the optimal resolution, color depth, file format and paper size for common scanning tasks, which can also be easily changed at any time. The Xerox DocuMate 5445 can quickly convert a large number of documents into electronic data, so it provides smooth usage even in offices with many users. Scanning documents into data makes it possible to consolidate information, which improves productivity. And it lowers the cost of handling documents and reduces the space needed to store them. -
Reliable paper feed mechanism
Another unique feature of the Xerox DocuMate 5445 are the paper feed rollers. The rollers rotate independently left and right to reduce document skewing during scanning. In addition, the active double-feed prevention roller reverses rotation the instant that the leading document leaves the paper feed section to prevent the double-feeding of documents that are simply stuck together. However, there are documents for which scanning should not be stopped even when doublefeeding is detected. Those include envelopes and documents with sticky notes attached. When the Xerox DocuMate 5445 pauses at one of these documents, scanning is easily resumed with the touch of a button. -
Hardware based image processing
Hardware image processing ensures that the scanners maintain their high scanning speeds even with multiple image processing functions selected. Scanning functions are handled by the onboard chip rather than the connected PC. Users can take advantage of advanced image processing functions, including dynamic thresholding, automatic cropping, automatic straightening, and blank page removal, without sacrificing scanning speed, and nearly doubling the efficiency of their scanning workflows.
- Xerox DocuMate 5445 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Light Source
- LED
- Max Supported Document Size
- 216 x 2540 mm
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi
- Max Document Scan Speed
- 45 ppm (mono) / 45 ppm (colour)
- Max Document Size
- 216 mm x 2540 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 75 sheets
- Duty Cycle
- 4000 scans per day
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
- 31.8 cm x 28 cm x 24.1 cm
- 4 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 216 x 2540 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi
- Bulb / Light Source Type
- LED
- Max Document Scan Speed B/W
- 45 ppm
- Max Document Scan Speed Colour
- 45 ppm
- Duty Cycle
- Scanner Speed Details
- 45 ppm - black & white - A4 - 200 dpi , 45 ppm - colour - A4 - 200 dpi , 45 ppm - black & white - Letter - 200 dpi , 45 ppm - colour - Letter - 200 dpi , 90 ipm - duplex - black & white - A4 - 200 dpi , 90 ipm - duplex - colour - A4 - 200 dpi , 90 ipm - duplex - black & white - Letter - 200 dpi , 90 ipm - duplex - colour - Letter - 200 dpi
- Scanner Features
- Ultrasonic Double Feed Detection, Dog-Ear Detection
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 216 mm x 2540 mm
- Plain paper
- Supported Document Size Details
- ADF - up to 216 x 2540 mm
- Automatic
- 75 sheets
- USB 2.0
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Device
- External power adapter
- Software Included
- Drivers & Utilities, Nuance OmniPage Professional, Nuance PaperPort, Visioneer OneTouch, Visioneer Acuity, Nuance PDF Converter, Visioneer DriverPLUS
- OS Required
- System Requirements Details
- Windows XP/Vista/7/8 - Pentium 4 RAM 2 GB - HD 350 MB
- 31.8 cm
- 28 cm
- 24.1 cm
- 4 kg
