The Xerox DocuMate 4790 is the ideal scanner for both large-volume and distributed scanning environments. It has a duty cycle of up to 10,000 sheets per day and has been engineered with innovative features for easy operation and productive batch scanning, including stapled document, ultrasonic double feed detection and support for long document scanning.
The Xerox DocuMate 4790 scans up to 90 ppm and 180 ipm and includes a 200-page automatic document feeder that accepts up to A3 size documents and can handle nearly any mix of paper in various sizes and thicknesses. Its unique paper feed mechanism minimizes the possibility of damaging important documents and ensures precise feeding to make your office work even more efficient.
The scanning glass is protected by the use of various sensors that detect stapled pages and automatically interrupt the scan process. It is also equipped with ultrasonic multi-feed detection and an innovative self-cleaning function that removes dust from the scanning glass to ensure consistently high image quality.
The Xerox DocuMate 4790 has a convenient clamshell design that allows direct and straightforward access to the entire paper path, so a user can clear paper jams, clean the unit, or replace rollers easily without having to call a service technician.
The Xerox DocuMate 4790 provides both high-quality image enhancement and increased productivity with Kofax VRS Professional AIPE-EBC for auto-everything scanning, including auto rotation, blank page deletion and auto color detect. VRS Professional improves your workflow and reduces the total time required to finish even the largest batches of mixed documents.
The DocuMate 4790 is powered by Visioneer OneTouch scanning technology for simplifying scan jobs and workflows. The scanner also has an easy-to-read LCD on the front that reminds the user of the resolution, color mode, file type, processing and final destination of the scanned document. You'll find the Xerox DocuMate 4790 to be the kind of advanced and reliable equipment you expect to come from Xerox.
Efficient scanning
The Xerox DocuMate 4790 is equipped with automatic duplexing, allowing for fast and efficient two-sided scanning without the need for manual intervention. This feature, combined with a 200-sheet feeder capacity, makes it ideal for handling large volumes of documents effortlessly. -
High-quality imaging
With a color depth of 24-bit and grayscale depth of 8-bit, the DocuMate 4790 delivers high-quality images in 16.7 million colors and 256 gray levels, respectively. This ensures that every scan captures all the details with accurate color reproduction and nuanced shades of gray. -
Versatile connectivity
Featuring a USB 2.0 interface, the DocuMate 4790 offers easy and reliable connectivity to PCs. This ensures a seamless integration into existing workflows, making it a versatile addition to any office environment.
- Xerox DocuMate 4790 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Dual CCD
- Max Supported Document Size
- A3 (297 x 420 mm)
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi
- Max Document Scan Speed
- 90 ppm (mono) / 90 ppm (colour)
- Max Document Size
- 305 mm x 2540 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 200 sheets
- Duty Cycle
- 15000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
- Microsoft Certification
- Compatible with Windows 7
- 46.8 cm x 44.4 cm x 33.9 cm
- 18 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 2.0
- A3 (297 x 420 mm)
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi
- Scan Mode
- Single/duplex pass
- Dual CCD
- Max Document Scan Speed B/W
- 90 ppm
- Max Document Scan Speed Colour
- 90 ppm
- Duty Cycle
- Scanner Speed Details
- 90 ppm - black & white - A4 / Letter - 200 dpi , 90 ppm - colour - A4 / Letter - 200 dpi , 70 ppm - black & white - A4 / Letter - 300 dpi , 70 ppm - colour - A4 / Letter - 300 dpi
- Scanner Features
- Ultrasonic Double Feed Detection, Visioneer OneTouch with Kofax VRS Technology, Ionizer, built-in LCD screen, stapled document detection
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 305 mm x 2540 mm
- Plain paper
- Supported Document Size Details
- ADF - up to 305 x 2540 mm
- Automatic
- 200 sheets
- Interfaces Details
- USB 2.0 - Type B
- Included Accessories
- Roller cleaning paper, shading paper, cleaning paper, blower brush, shading caution leaflet, DFP roller pad
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- Power Consumption Operational (Standby)
- 110 Watt (45 Watt)
- Software Included
- Nuance OmniPage Professional, Visioneer OneTouch with Kofax VRS Technology, Kofax VRS Basic
- OS Required
- System Requirements Details
- Windows XP - Pentium 4 RAM 512 MB - HD 350 MB , Windows 7/Vista - Pentium 4 RAM 1 GB - HD 350 MB
- 46.8 cm
- 44.4 cm
- 33.9 cm
- 18 kg
- Limited warranty - 1 year , Technical support - phone consulting , Technical support - web support
- 15 °C
- 30 °C
- 20 - 80%
