The Xerox DocuMate 4760 delivers high-quality production scanning to any organization, at an affordable price. With its powerful combination of image quality, easy to use features and fast scanning speeds, it is the perfect solution for businesses looking to achieve high levels of flexibility within a low volume production scanning environment. The DocuMate 4760 scans documents at 60 ppm (simplex) and 120 ipm (duplex) at 300 dpi in color, grayscale, and black & white modes. It also includes a 150-page capacity Automatic Document Feeder (ADF), has the ability to scan a wide range of mixed document sizes (up to A3 / 11" x 17") and supports long document scanning up to 38" (965 mm).
Efficient scanning
The DocuMate 4760 offers automatic duplexing, allowing for fast double-sided scanning, which maximizes productivity for any office setting. -
High capacity
With a feeder capacity of 150 sheets, this scanner is designed to handle large volumes of documents, making it ideal for busy environments. -
Superior image quality
A color depth of 24-bit and grayscale depth of 8-bit ensure that scanned documents have vivid colors and sharp grayscale, suitable for all professional needs. -
Versatile document handling
Capable of scanning documents up to 297 x 965 mm in size through the ADF, the DocuMate 4760 can accommodate a wide range of document types. -
Advanced technology
Features like Ultrasonic Double Feed Detection and Visioneer OneTouch with Kofax VRS Technology enhance the scanning process, ensuring efficiency and reliability.
- Xerox DocuMate 4760 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Dual CCD
- Max Supported Document Size
- A3 (297 x 420 mm)
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi
- Max Document Scan Speed
- 60 ppm (mono) / 60 ppm (colour)
- Max Document Size
- 297 mm x 965 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 150 sheets
- Duty Cycle
- 5000 scans per day
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
- 42.7 cm x 27.7 cm x 21.8 cm
- 9 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 2.0
- A3 (297 x 420 mm)
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi
- Scan Mode
- Single/duplex pass
- Dual CCD
- Max Document Scan Speed B/W
- 60 ppm
- Max Document Scan Speed Colour
- 60 ppm
- Duty Cycle
- Scanner Speed Details
- 60 ppm - black & white - 200 dpi , 120 ipm - duplex - black & white - 200 dpi , 60 ppm - colour - 150 dpi , 120 ipm - duplex - colour - 150 dpi
- Scanner Features
- Ultrasonic Double Feed Detection, Visioneer OneTouch with Kofax VRS Technology
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 297 mm x 965 mm
- Plain paper
- Supported Document Size Details
- ADF - up to 297 x 965 mm
- Automatic
- 150 sheets
- Interfaces Details
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Device
- External power adapter
- Power Consumption Operational (Standby)
- 39.5 Watt (11.4 Watt)
- Software Included
- Kofax VirtualReScan Basic, Nuance OmniPage Professional, Visioneer OneTouch with Kofax VRS Technology
- OS Required
- System Requirements Details
- Windows XP SP2 - Pentium 4 RAM 1 GB - HD 350 MB , Windows 7/Vista - Pentium 4 RAM 2 GB - HD 350 MB
- 42.7 cm
- 27.7 cm
- 21.8 cm
- 9 kg
- Limited warranty - 1 year , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
