The DocuMate 4440 is a fast and easy to use scanner that enables users with an effective way to greatly reduce paper chaos, storage requirements, and security risks associated with unorganized paperwork at home or the office. The DocuMate 4440 is packed with features that will change how you look at and manage paper documents and information.
Efficient duplex scanning
The DocuMate 4440 is equipped with automatic duplexing, allowing for fast double-sided scanning which enhances productivity and efficiency in any office setting. -
High-quality imaging
With a 24-bit color depth and 8-bit grayscale depth, the DocuMate 4440 delivers high-quality, vibrant scans with 16.7 million colors and 256 gray levels, ensuring that your documents look as sharp digitally as they do on paper. -
Versatile document handling
Designed to accommodate up to 50 sheets in its automatic document feeder and capable of scanning a wide range of document sizes through its ADF mode, this scanner is built for office environments with diverse scanning needs. -
Rapid scanning capability
Achieve remarkable productivity with the DocuMate 4440's capability to scan at speeds of up to 40 pages per minute in both black and white and color, making it a powerful tool for any task requiring quick digitization of documents. -
Comprehensive compatibility
Featuring USB 2.0 connectivity and compliance with ISIS, TWAIN, and WIA standards, the DocuMate 4440 ensures seamless integration and compatibility with a wide range of PC systems and software applications.
- Xerox DocuMate 4440 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Dual CCD
- Light Source
- White LED
- Max Supported Document Size
- 216 x 2997 mm
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 40 ppm (mono) / 40 ppm (colour)
- Max Document Size
- 216 mm x 2997 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, plastic card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 5000 scans per day
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
- Microsoft Certification
- Compatible with Windows 7
- 30.5 cm x 52.8 cm x 35.2 cm
- 3.85 kg
- Interface Type
- USB 2.0
- 216 x 2997 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Dual CCD
- Bulb / Light Source Type
- White LED
- Max Document Scan Speed B/W
- 40 ppm
- Max Document Scan Speed Colour
- 40 ppm
- Duty Cycle
- Scanner Speed Details
- 80 ipm - duplex - black & white - 200 dpi , 80 ipm - duplex - colour - 150 dpi , 40 ppm - black & white - 200 dpi , 40 ppm - colour - 150 dpi , 30 ppm - black & white - 300 dpi , 30 ppm - colour - 300 dpi , 30 ppm - greyscale - 300 dpi , 60 ipm - duplex - colour - 300 dpi , 60 ipm - duplex - black & white - 300 dpi , 60 ipm - duplex - greyscale - 300 dpi
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 216 mm x 2997 mm
- Supported Document Size Details
- ADF - up to 216 x 2997 mm
- Automatic
- 50 sheets
- Interfaces Details
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- Power Device
- External power adapter
- Software Included
- Kofax VirtualReScan, Nuance OmniPage Professional, Nuance PaperPort, Visioneer OneTouch, Visioneer Acuity, Nuance PDF Converter
- OS Required
- System Requirements Details
- Windows XP - Pentium 4 RAM 512 MB - HD 350 MB (USB) , Windows Vista/7/8 - Pentium 4 RAM 1 GB - HD 350 MB (USB)
- 30.5 cm
- 52.8 cm
- 35.2 cm
- 3.85 kg
