Xerox DocuMate 3920 Document Scanner
Quicklinx: 9M4QWS00 Mfr#: 003R92565
Direct connect scanners are a vital part of your document capture strategy, but network scanners, like the DocuMate 3920, are the perfect solution for an office that has shared scanner needs. Network accessible scanning achieves two major goals for your document workflow and capture with great efficiency and ease of use. First, a network scanner can be conveniently located in common areas and does not require a PC connection. Second, the scanner can easily access broad network connections to file servers, email servers, FTP locations and printers and fax servers. The DocuMate 3920 is designed with convenience and ease to support small to medium workgroups and offices through a standard Ethernet connection and provides a secure multi-user access, with easy administration, through an embedded form-based web page configuration. No expensive IT department or network contractor is needed to begin scanning documents to local servers or FTP locations. Email can now be delivered anywhere on the Internet (or simple fax sending and receiving) through standard phone line.
  • Scan to email
    The scan-to-email feature lets you scan paper-based documents in full color and e-mail them in PDF, JPEG, or TIFF file formats directly from the DocuMate 3920. As a result, you can send the scanned document simultaneously to a lot of multiple addresses or distribution lists. The DocuMate 3920 supports LDAP (lightweight directory access protocol) for direct access to Microsoft Exchange Server email directories. Plus, there are a total of 2000 custom e-mail addresses which can be added to the device.
  • Scan to filing
    The scan-to-filing feature allows users to scan documents and save them to a PC folder or to any server in the network or externally on the Internet through FTP, HTPP, HTTPS, or CIFS. The built-in Ethernet connection gives the device full or limited network privileges as defined by the network administrator.
  • Digital copying
    When the DocuMate 3920 is directly connected to a PCL5-enabled printer through its USB connection, the configuration turns into a digital copier. Through the easy-to-use font panel, you can make black and white copies just like you do on a regular copy machine.
    The scan-to-email feature lets users scan paper-based documents in full color and e-mail them in PDF, JPEG, or TIFF file formats directly from the scanner. The Xerox DocuMate 3920 supports LDAP (lightweight directory access protocol) for direct access to Microsoft Exchange Server email directories and up 2000 custom e-mail addresses can be added to the device.
  • Multiple pages sending
    With an Auto Document Feeder (ADF), the DocuMate 3920 allows a 50-page document stack to be continuously scanned and transmitted at one time in reliable quality to increase your efficiency.
  • Fax
    When the DocuMate 3920 is connected to a supported printer and a telephone line, this configuration can be used as a send/receive fax machine that prints incoming faxes. Add to this a phonebook speed dial, and broadcast fax directory so send faxes to large groups to increase your efficiency. There is a full numeric keypad to enter fax phone numbers as simply as using your traditional fax machine.
  • Large and easy-to-use touch panel
    A large 7-inch, bright color LCD shows all operation modes clearly. Simply make a few touches on the LCD screen, you can finish your job within seconds. The screen is highly responsive to your touch and the soft QWERTY keyboard makes any data entry easy and fast.
  • Network management tool
    The DocuMate 3920 network management tool allows the administrator to easily configure one or multiple DocuMate 3920 devices on the network. The form-driven web page allows easy creation of up to 2000 email addresses and 50 filing destinations to support document scanning workflows at the device and on the network. The DocuMate 3920 supports LDAP for direct access to Microsoft Exchange Server email directories and SMTP server support so that small businesses without elaborate Exchange servers or large IT departments can configure their scan-to-email with Internet and ISP based mail services. The built-in Ethernet connection gives the device full or limited network privileges via a simple web-based network management tool.
Xerox DocuMate 3920 - MFP option - desktop - USB 2.0, LAN
Interface Type
USB 2.0, LAN
Scanning Sensor Type
CCD
Light Source
Xe-gas cold cathode fluorescent lamp
Additional Functions
Email, fax, scan to print, scan to network share
Max Supported Document Size
Legal (216 x 356 mm)
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Size
216 mm x 297 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Duty Cycle
1000 scans per day
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
48 cm x 47.5 cm x 20.5 cm
10.2 kg
Interface Type
USB 2.0, LAN
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
CCD
Bulb / Light Source Type
Duty Cycle
1000 scans per day
Scanner Speed Details
20 ppm - black & white - 200 dpi , 14 ipm - duplex - black & white - 200 dpi , 10 ppm - colour - 150 dpi
Scanner Features
7" touch screen TFT display
Media Handling
Max Document Size
216 mm x 297 mm
Plain paper
Supported Document Size Details
ADF - up to Legal (216 x 356 mm) , Flatbed - up to 216 x 297 mm
Automatic
50 sheets
Supported Protocols
FTP, HTTP, SMTP, HTTPS, LDAP
USB 2.0 - Type B , 2 x phone line , LAN , USB 2.0 - Type A
1 x USB cable , 1 x phone cable
External power adapter
Software Included
Network Management Tool
48 cm
47.5 cm
20.5 cm
10.2 kg
