Xerox DOCUMATE 3640
Quicklinx: 7206WS00 Mfr#: 003R92152
The DocuMate 3640 is a departmental duplex flatbed scanner with the automatic document feeder (ADF) that scans in duplex mode. The A4/legal flatbed is the only departmental scanner that can be programmed to automatically scan customisable applications or devices. Ultrasonic double feed detection insures that no pages are missed due to a misfeed or stapled document in the ADF tray. Documents can be converted to text-searchable PDF in one easy step.
The Xerox DocuMate 3640 is the perfect solution for company wide scanning solutions and enables businesses to achieve high levels of productivity by distributing fast, costeffective departmental scanners throughout the organization.
  • Efficient duplexing
    The DocuMate 3640 offers automatic duplexing, allowing for fast double-sided scanning without manual intervention. This feature enhances productivity and saves time, making it ideal for busy office environments.
  • High-capacity feeding
    With an 80-sheet feeder capacity, this scanner is designed for high-volume tasks. It can handle up to 5000 scans per day, ensuring that large scanning jobs are completed efficiently.
  • Versatile document handling
    Supporting a wide range of document sizes, from small cards to legal-sized documents, the DocuMate 3640 is equipped to manage various scanning needs. Its flexibility makes it suitable for diverse office settings.
  • Superior image quality
    The scanner's 24-bit color depth and 8-bit grayscale depth produce high-quality images with accurate color reproduction and nuanced grayscale. This ensures that scanned documents are clear and detailed.
  • Advanced scanning technology
    Equipped with Visioneer OneTouch with Kofax VRS Technology, the DocuMate 3640 delivers optimized scanning performance. This technology simplifies the scanning process and enhances the quality of the scanned images.
Xerox DocuMate 3640 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Max Supported Document Size
216 x 965 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
40 ppm (mono) / 40 ppm (colour)
Max Document Size
216 mm x 965 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
80 sheets
Duty Cycle
5000 scans per day
Microsoft Windows 2000 SP4, Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista
53.1 cm x 41.1 cm x 22.4 cm
10.3 kg
Interface Type
USB 2.0
216 x 965 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Max Document Scan Speed B/W
40 ppm
Max Document Scan Speed Colour
40 ppm
Duty Cycle
5000 scans per day
Scanner Speed Details
80 ipm - duplex black & white (back) 200 dpi (back) , 80 ipm - duplex colour (back) 150 dpi (back) , 40 ppm black & white (back) 200 dpi (back) , 40 ppm colour (back) 150 dpi (back)
Scanner Features
TWAIN, ISIS, WIA
Media Handling
Max Document Size
216 mm x 965 mm
Plain paper
Supported Document Size Details
ADF - up to 216 x 965 mm , Flatbed - up to Legal (216 x 356 mm)
Automatic
80 sheets
Interfaces Details
USB 2.0 - Type B
1 x USB cable
External power adapter
Software Included
QuickScan Pro (Demo), Kofax VirtualReScan Basic, Nuance OmniPage Professional, Nuance PaperPort, Visioneer OneTouch
Additional Requirements
DVD-ROM, USB port (compatible with 2.0 specification)
System Requirements Details
Windows 2000 SP4 - Pentium 4 RAM 512 MB - HD 500 MB , Windows XP SP2 - Pentium 4 RAM 512 MB - HD 500 MB , Windows 7/Vista - Pentium 4 RAM 1 GB - HD 500 MB
53.1 cm
41.1 cm
22.4 cm
10.3 kg
