The Xerox DocuMate 3220 is a next generation duplex scanner that combines an A4/US Letter sized flatbed and 50-sheet capacity ADF (Automatic Document Feeder) to create an entry level scanner with all the best features of higher-end products. It can easily support the scanning needs of individuals in small and home offices or workgroups in the corporate world. Installation is as simple as inserting one DVD-ROM disc and connecting the scanner to a host PC via a high-speed USB 2.0 cable.
The Xerox DocuMate 3220 includes a powerful and robust productivity software bundle that provides all the tools for a document centric professional who needs to better organize, manipulate and communicate paper in their business. Scan checks, documents, business cards, credit cards, photos or thick card stock with one touch simplicity. The Xerox DocuMate 3220 front panel provides simple single button control for at-device scanning to any of 9 preset and up to 99 completely customizable OneTouch scan profiles.
Efficient scanning
The DocuMate 3220 offers automatic duplexing, allowing for fast double-sided scanning, which maximizes productivity for any office or home setup. -
High-quality images
With a color depth of 24-bit, the DocuMate 3220 produces vivid images with 16.7 million colors, ensuring that your documents look as sharp digitally as they do on paper. -
Versatile document handling
Supporting a wide range of document types including plain paper, and equipped with an automatic document feeder, this scanner is designed to meet diverse scanning needs. -
Optimal compatibility
Fully compatible with both Mac and PC systems and certified for Windows 7, the DocuMate 3220 ensures seamless integration into existing workflows. -
High-speed scanning
Achieve remarkable efficiency with scan speeds of up to 23 ppm in black and white, enhancing office productivity and reducing wait times.
- Xerox DocuMate 3220 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Dual CIS
- Max Supported Document Size
- 222 x 965 mm
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 colours) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi
- Max Document Scan Speed
- 23 ppm (mono) / 12 ppm (colour)
- Max Document Size
- 222 mm x 965 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 1500 scans per day
- Power
- AC 220 V
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Windows 8, Windows 10
- Microsoft Certification
- Compatible with Windows 7
- 45.3 cm x 33 cm x 13.9 cm
- 4.6 kg
- Interface Type
- USB 2.0
- 222 x 965 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi
- Scan Mode
- Single/duplex pass
- Dual CIS
- Max Document Scan Speed B/W
- 23 ppm
- Max Document Scan Speed Colour
- 12 ppm
- Duty Cycle
- Scanner Speed Details
- 46 ipm - duplex black & white (back) 200 dpi (back) , 23 ppm black & white (back) 200 dpi (back) , 24 ipm - duplex colour (back) 150 dpi (back) , 12 ppm colour (back) 150 dpi (back)
- Scanner Features
- Visioneer OneTouch with Kofax VRS Technology
- TWAIN, WIA
Media Handling
- Max Document Size
- 222 mm x 965 mm
- Plain paper
- Supported Document Size Details
- ADF - up to 222 x 965 mm , Flatbed - up to 216 x 299 mm
- Automatic
- 50 sheets
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- Power Device
- External power adapter
- Voltage Required
- AC 220 V
- Software Included
- Nuance OmniPage Professional, Nuance PaperPort, Visioneer OneTouch with Kofax VRS Technology, NewSoft Presto! PageManager, ExactScan 2 Lite
- OS Required
- System Requirements Details
- Windows XP - Pentium 4 RAM 512 MB - HD 350 MB (USB) , Windows Vista/7/8/10 - Pentium 4 RAM 1 GB - HD 350 MB (USB) , MacOS X 10.4 or later - PowerPC G5 - 1.6 GHz - RAM 512 MB - HD 350 MB (USB) , MacOS X 10.4 or later - Intel Core - 1.83 GHz - RAM 512 MB - HD 350 MB (USB)
- 45.3 cm
- 33 cm
- 13.9 cm
- 4.6 kg
