The Xerox DocuMate 3125 is an A4 desktop document scanner with speeds of 25 ppm and 44 ipm (images per minute, duplex) in black and white, grayscale and color at 200 or 300 dpi. Durability tests support a daily duty cycle of 3,000 pages. The scanner uses a CIS (Contact Image Sensor) and an LED light source for efficient power consumption. The unit offers a 50-sheet document feeder for document widths up to 8.5". Long capability is supported up 38". The DocuMate 3125 has ultrasonic double feed detection so that stapled or other misfed documents can be sensed before they are crumpled, destroyed or cause a jam.
The DocuMate 3125 scanner allows users to scan to the "destination" of their choice by pressing a single button, eliminating the multiple steps usually required to save scanned documents in popular file formats. Simply select one of 9 preset (yet completely user configurable) and your documents will be scanned with the correct settings for resolution, color, cropping, and file format.
Efficient scanning
With automatic duplexing, the Xerox DocuMate 3125 offers efficient two-sided scanning, reducing the time and effort required to process documents. -
High-quality images
This scanner captures your documents in vivid detail with a color depth of 24-bit (16.7 million colors) and grayscale depth of 8-bit (256 gray levels), ensuring that your scans have the clarity and color accuracy needed for all your business needs. -
Versatile document handling
Designed to accommodate a variety of document sizes up to 216 x 965 mm and types including plain paper and plastic cards, the DocuMate 3125 meets diverse scanning requirements. -
Robust daily duty cycle
Ready to handle up to 3000 scans per day, this scanner is built for durability and reliability, making it suitable for busy office environments. -
Easy connectivity
Featuring a USB 2.0 interface, the DocuMate 3125 ensures easy connection to PCs, facilitating a seamless integration into your existing workflow.
- Xerox DocuMate 3125 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Max Supported Document Size
- 216 x 965 mm
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi
- Max Document Size
- 216 mm x 965 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, plastic card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 3000 scans per day
- System Requirements
- Microsoft Windows Vista / XP / 7
- 28.4 cm x 26.1 cm x 26.1 cm
- 2.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 216 x 965 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi
- Duty Cycle
- Scanner Speed Details
- 25 ppm - black & white - 200 dpi , 25 ppm - colour - 150 dpi , 44 ipm - duplex - black & white - 200 dpi , 44 ipm - duplex - colour - 150 dpi
- Scanner Features
- Visioneer OneTouch with Kofax VRS Technology
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 216 mm x 965 mm
- Automatic
- 50 sheets
- Interfaces Details
- USB 2.0
- Cables Included
- 1 x USB cable
- EMC
- ENERGY STAR Certified
- Software Included
- Presto! BizCard, Nuance OmniPage Professional, Nuance PaperPort, Visioneer OneTouch with Kofax VRS Technology
- OS Required
- System Requirements Details
- Windows XP - Pentium 4 RAM 512 MB - HD 350 MB , Windows 7/Vista - Pentium 4 RAM 1 GB - HD 350 MB
- 28.4 cm
- 26.1 cm
- 26.1 cm
- 2.3 kg
