The Xerox DocuMate 152i, color sheet-fed document scanner, now scans up to 50 images per minute (ipm) in duplex mode, includes a 50-page automatic document feeder and has the ability to automatically scan documents into searchable PDF files. The scanner also offers a more powerful suite of bundled software designed to help you organize and find the information important to you.
Efficient scanning
The DocuMate 152i offers automatic duplexing, allowing for fast and easy two-sided scanning, enhancing productivity and efficiency in any office setting. -
High-quality imaging
With a color depth of 24-bit and a grayscale depth of 8-bit, this scanner produces high-quality images in full color or grayscale, capturing every detail with clarity. -
Versatile document handling
Equipped with a 50-sheet automatic document feeder and capable of scanning up to 2500 scans per day, the DocuMate 152i can handle a variety of document types and sizes, making it a versatile choice for busy environments. -
Convenient connectivity
Featuring a USB 2.0 interface, the DocuMate 152i offers easy connectivity to both Mac and PC systems, ensuring seamless integration into any workflow. -
Compact and reliable
Designed as a desktop form factor with an external power adapter, this document scanner is both compact and reliable, fitting easily into any workspace and supporting a high daily duty cycle.
- Xerox DocuMate 152i - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Light Source
- White LED
- Max Supported Document Size
- Legal (216 x 356 mm)
- Input Type
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi
- Max Document Size
- 216 mm x 356 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Duty Cycle
- 2500 scans per day
- System Requirements
- Microsoft Windows XP SP2, Microsoft Windows 7, Microsoft Windows Vista
- Microsoft Certification
- Compatible with Windows 7
- 30.9 cm x 16 cm x 14.1 cm
- 2.7 kg
- Interface Type
- USB 2.0
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi
- Bulb / Light Source Type
- White LED
- Duty Cycle
- TWAIN, WIA
Media Handling
- Max Document Size
- 216 mm x 356 mm
- Plain paper
- Supported Document Size Details
- ADF - up to Legal (216 x 356 mm)
- Automatic
- 50 sheets
- Interfaces Details
- USB 2.0
- Cables Included
- 1 x USB cable
- Power Device
- External power adapter
- Software Included
- Drivers & Utilities, Visioneer Acuity, Nuance Power PDF, Visioneer Scan Utility for Mac, Nuance PaperPort Professional, Nuance OmniPage Ultimate
- OS Required
- System Requirements Details
- Windows XP - Pentium 4 RAM 512 MB - HD 350 MB , Windows 7/Vista - Pentium 4 RAM 1 GB - HD 350 MB
- 30.9 cm
- 16 cm
- 14.1 cm
- 2.7 kg
