wePresent WiPG-1600 is the tool you've been missing to integrate your collaborative spaces. In classrooms or meeting spaces with existing hardware, the WiPG-1600 integrates seamlessly to bring you wireless BYOD environments.
wePresent WiPG-1600 is a cross-platform BYOD presentation device, featuring a 64-user capacity with moderator control, advanced security, the ability to integrate into environments with touchscreen displays, and the capability to mirror Chromebooks as well as iOS devices through Apple AirPlay.
- wePresent WiPG-1600 - presentation server
- Presentation server
- Form Factor
- External
- Processor
- 800 MHz
- Data Link Protocol
- OS Required
- Apple MacOS X 10.7 or later, Apple iOS 4.2 or later, Microsoft Windows Vista / XP / 7 / 8, Windows 10, Android 2.4 or later
- 15.9 cm x 9.1 cm x 2.99 cm
- 275 g
- 2-year warranty
- 15.9 cm
- 9.1 cm
- 2.99 cm
- 275 g
Processor / Memory / Storage
- Processors Installed
- 800 MHz
- Form Factor
- External
- Connectivity Technology
- Wired
- TCP/IP, DHCP
- Remote Management Protocol
- SNMP, HTTPS
- Status Indicators
- Power
- Reset button, Apple AirPlay
- Encryption Algorithm
- SSL, 128-bit AES
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- 1 x VGA - HD-15 , 1 x HDMI output , 1 x 1000Base-T - RJ-45 , 3 x USB 2.0 - Type A , 1 x audio line-out - mini-jack
- FCC
- Power Device
- External power adapter
- OS Required
- Limited warranty - 2 years
