WD 2TB Blue 2.5" SATA 5400RPM Internal Hard Drive
CLEARANCE!
Clearance
Limited Time Offer
Quicklinx: BKXVWS00 Mfr#: WD20NPVZ
WD Blue hard drives deliver solid performance and reliability while providing you with all of the space you need to hold enormous amounts of photos, videos, and files. WD Blue hard drives are designed for use as primary drives in notebooks and external enclosures.
  • StableTrac
    Motor shaft affixed to the baseplate and top cover stabilizes platters for accurate tracking during read and write operations, yielding higher drive data throughput in harsh shock and vibration environments. Supporting the top cover with the shaft also increases robustness to pinch forces.
  • Available SATA
    6 Gb/s interface The SATA 6 Gb/s interface provides greater flexibility for use with the latest chipsets as well as backwards compatibility to legacy systems with SATA 3 Gb/s requirements. (xPVX, and xPCX models only).
  • NoTouch Ramp Load technology
    The recording head never touches the disk media ensuring significantly less wear to the recording head and media as well as better drive protection in transit.
  • The original WD
    Blue drives are designed and manufactured with the proven technology found in WD's original hard drives.
  • WD quality
    Built to the highest standards of quality and reliability, these drives offer the features and capacity ideal for your everyday computing needs.
  • Low power consumption
    State-of-the-art seeking algorithms and advanced power management features ensure low power consumption and long battery life.
  • Upgrading your drive is easy
    Acronis True Image WD Edition Software, available as a free download on the WD Support site, enables you to copy all your data to a new drive so you don't have to reinstall your operating system to get all the benefits of a new drive.
  • Compatible
    15 mm 2.5-inch mobile drives is designed for thin and light mobile applications, and is also compatible with most standard 9.5 mm bays (xPCX, LPVT, and LPVX models only).
  • Quiet
    In a notebook drive, silence is golden. WD's exclusive noise reducing technologies yield one of the quietest 2.5-inch hard drives on the market.
WD Blue WD20NPVZ - hard drive - 2 TB - SATA 6Gb/s
Hard drive - internal
2 TB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
8 MB
Spindle Speed
5200 rpm
NoTouch ramp load technology, Advanced Format technology, Advanced Power Management technology, S.M.A.R.T.
69.85 mm x 100.2 mm x 15 mm
180 g
2 TB
2.5"
SATA 6Gb/s
Buffer Size
8 MB
69.85 mm
100.2 mm
15 mm
180 g
Performance
Drive Transfer Rate
600 MBps (external)
Seek Time
6.5 ms (average)
Spindle Speed
5200 rpm
Reliability
Non-Recoverable Errors
1 per 10^14
Load / Unload Cycles
600,000
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
1.7 Watt (read) , 1.7 Watt (write) , 0.2 Watt (sleep) , 0.2 Watt (standby) , 0.8 Watt (idle)
Apple MacOS, Microsoft Windows 7 / Windows 8
RoHS 2011/65/EU
60 °C
