WatchGuard Technologies XTM 535 3 Years
Quicklinx: BJTCWS00 Mfr#: WG535003
The next-generation WatchGuard XTM 535 has up to 3.0 Gbps firewall throughput, 550 Mbps VPN throughput, and six 1GgE ports. Security features include application-layer content inspection, full HTTPS inspection, and VoIP support. Flexible, centralized management tools allow administrators access from one intuitive console or a scriptable CLI. Real-time monitoring and rich reporting are included at no additional cost. Ships with the Pro version of the Fireware XTM OS for advanced networking features including high availability (active/active), dynamic and policy-based routing, and server load balancing. LiveSecurity Service provides hardware warranty with hardware warranty, technical support, software updates, and concise threat alerts.
  • Fast 2.3 Gbps throughput
    The XTM 5 Series puts other appliances in its class to shame with up to 2.3 Gbps for firewall throughput and 800 Mbps XTM throughput, even with all security services and deep packet inspection enabled. The 5 Series delivers formidable performance for exceptional value.
  • Fireware XTM included
    The Fireware XTM OS increases security and networking capabilities. When you're ready, it's easy to upgrade to the Pro version of the OS for even more features.
  • 3 ways to manage your appliance
    Now you have the power to choose how you manage your WatchGuard appliance including, WatchGuard System Manager, the command line interface, and a web UI for access from anywhere, anytime.
  • Skype blocking
    Block Skype connections to and from protected hosts to keep productivity high and prevent malware injections and data leakage.
  • Reporting in the Browser
    Provides a web-based, customizable reports portal designed to be hosted with direct Internet access for easy report selection and viewing.
  • Remote/external log server/report server DB
    MSSPs and larger organizations can now take advantage of the ability to isolate logging and reporting on a separate PC for high performance, scalability, and redundancy.
  • Self Health monitoring
    Health monitoring for the WSM logging and reporting system helps minimize disruptions and maintain high service levels in these critical functions.
  • Green security
    The firewalls are designed with efficiency in mind, consuming very little energy. Compare the power consumption to other security products and see how WatchGuard can make your data center more energy efficient. Green up your network with WatchGuard.
  • An investment in your security
    Model upgradability ensures your network security investment is protected with the ability to easily upgrade its performance, capacity, and security capabilities as business requirements change and new threats emerge.
WatchGuard XTM 5 Series 535 - security appliance - with 3 years LiveSecurity Service
Security appliance
Bundled Services
External - 1U
Ports Qty
7
Performance
Firewall throughput: 3 Gbps , VPN throughput: 550 Mbps , Antivirus throughput: 1.81 Gbps , IPS throughput: 1.47 Gbps , Aggregate throughput: 960 Mbps , Throughput: 12000 connections per second
Virtual interfaces (VLANs): 300 , Concurrent connections: 100000 , Nodes (LAN IPs): unlimited , Authenticated users: 1000 , Branch office VPN tunnels: 200 , Mobile IPSec VPN tunnels: 300 , Mobile SSL VPN tunnels: 300
VoIP Protocols
H.323, SIP
43.2 cm x 28.6 cm x 4.5 cm
7.3 kg
Security appliance
Bundled Services
Height (Rack Units)
1U
Built-in Devices
Status LCD
43.2 cm
28.6 cm
4.5 cm
7.3 kg
External
Ports Qty
7
Wired
Data Transfer Rate
1 Gbps
Network / Transport Protocol
PPTP, PPPoE, FTP, DNS, POP3, DDNS
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, HTTPS
Performance
Status Indicators
Power, status, link/activity
DoS attack prevention, DiffServ support, IPv6 support, Quality of Service (QoS), VPN failover, DHCP server, anti-spyware protection, DHCP relay, DHCP client
Encryption Algorithm
DES, Triple DES, MD5, IKE, SSL, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
SecurID, VASCO token authentication, Transparent Active Directory Authentication (Single Sign-on), XAUTH (RADIUS, LDAP, Active Directory)
IP Telephony
VoIP Protocols
H.323, SIP
1 x console , 2 x management , 6 x 1000Base-T - RJ-45 , 1 x 100Base-TX - RJ-45
Rack Mounting Kit
Included
MTBF
51,644 hours
CB, RoHS, FIPS 140-2, WEEE, REACH, Common Criteria EAL4+, NRTL
Internal power supply
10 - 85% (non-condensing)
