Get everything you need for complete unified threat management at a great price with the XTM 515 Security Bundle. The Bundle includes a next-generation WatchGuard XTM 515 security appliance with 2.0 Gbps firewall throughput, 210 Mbps VPN throughput, and six 1GgE ports. In addition, the Bundle delivers a full suite of UTM security subscriptions to boost protection in critical attack areas, including Application Control, Intrusion Prevention Service, WebBlocker, Gateway AntiVirus, spamBlocker, and Reputation Enabled Defense, along with LiveSecurity Plus for 24/7 technical support.
Fast 2.3 Gbps throughput
The XTM 5 Series puts other appliances in its class to shame with up to 2.3 Gbps for firewall throughput and 800 Mbps XTM throughput, even with all security services and deep packet inspection enabled. The 5 Series delivers formidable performance for exceptional value. -
Fireware XTM included
The Fireware XTM OS increases security and networking capabilities. When you're ready, it's easy to upgrade to the Pro version of the OS for even more features. -
3 ways to manage your appliance
Now you have the power to choose how you manage your WatchGuard appliance including, WatchGuard System Manager, the command line interface, and a web UI for access from anywhere, anytime. -
Skype blocking
Block Skype connections to and from protected hosts to keep productivity high and prevent malware injections and data leakage. -
Reporting in the Browser
Provides a web-based, customizable reports portal designed to be hosted with direct Internet access for easy report selection and viewing. -
Remote/external log server/report server DB
MSSPs and larger organizations can now take advantage of the ability to isolate logging and reporting on a separate PC for high performance, scalability, and redundancy. -
Self Health monitoring
Health monitoring for the WSM logging and reporting system helps minimize disruptions and maintain high service levels in these critical functions. -
Green security
The firewalls are designed with efficiency in mind, consuming very little energy. Compare the power consumption to other security products and see how WatchGuard can make your data center more energy efficient. Green up your network with WatchGuard. -
An investment in your security
Model upgradability ensures your network security investment is protected with the ability to easily upgrade its performance, capacity, and security capabilities as business requirements change and new threats emerge.
- WatchGuard XTM 5 Series 515 - security appliance - with 1 year Gateway AV/IPS, Application Control, spamBlocker, WebBlocker, Reputation Enabled Defense, LiveSecurity Plus Service Subscriptions
- Security appliance
- Bundled Services
- 1 year Gateway AV/IPS, Application Control, spamBlocker, WebBlocker, Reputation Enabled Defense, LiveSecurity Plus Service Subscriptions
- Form Factor
- External - 1U
- Ports Qty
- 7
- Data Link Protocol
- Performance
- Firewall throughput: 2 Gbps , VPN throughput: 210 Mbps , Antivirus throughput: 1.52 Gbps , IPS throughput: 900 Mbps , Aggregate throughput: 660 Mbps , Throughput: 12000 connections per second
- Capacity
- Virtual interfaces (VLANs): 100 , Concurrent connections: 40000 , Nodes (LAN IPs): unlimited , Authenticated users: 500 , Branch office VPN tunnels: 65 , Mobile IPSec VPN tunnels: 75 , Mobile SSL VPN tunnels: 65
- VoIP Protocols
- H.323, SIP
- Power
- AC 120/230 V (50/60 Hz)
- 43.2 cm x 28.6 cm x 4.5 cm
- 7.3 kg
- Bundled Services
- Height (Rack Units)
- 1U
- Built-in Devices
- Status LCD
- 43.2 cm
- 28.6 cm
- 4.5 cm
- 7.3 kg
- Form Factor
- External
- Ports Qty
- 7
- Connectivity Technology
- Wired
- Data Transfer Rate
- 1 Gbps
- PPTP, PPPoE, FTP, DNS, POP3, DDNS
- Remote Management Protocol
- SNMP 2, SNMP 3, HTTP, HTTPS
- Performance
- Capacity
- Status Indicators
- Power, status, link/activity
- DoS attack prevention, DiffServ support, IPv6 support, Quality of Service (QoS), VPN failover, DHCP server, anti-spyware protection, DHCP relay, DHCP client
- Encryption Algorithm
- DES, Triple DES, MD5, IKE, SSL, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
- Authentication Method
- SecurID, VASCO token authentication, Transparent Active Directory Authentication (Single Sign-on), XAUTH (RADIUS, LDAP, Active Directory)
IP Telephony
- VoIP Protocols
- H.323, SIP
- 1 x console , 2 x management , 6 x 1000Base-T - RJ-45 , 1 x 100Base-TX - RJ-45
- Rack Mounting Kit
- Included
- MTBF
- 51,644 hours
- CB, RoHS, FIPS 140-2, WEEE, REACH, Common Criteria EAL4+, NRTL
- Power Device
- Internal power supply
- Voltage Required
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
