WatchGuard Firebox M470 appliances combine strong security, high performance, and flexible management tools in one affordable solution for midsize businesses and distributed enterprises. The M470 delivers firewall throughput of 19.6 Gbps to keep traffic moving, with the best UTM throughput in its class - up to 3.1 Gbps - even with strong security enabled. Includes 8 1G ports, plus 1 SFP port for fiber or copper. Optional 4x10 Gb Fiber, 8x1 Gb Fiber, and 8x1 Gb Copper network interface modules enable flexible configurations. Flexible management tools give administrators access to security capabilities from an intuitive console, scriptable CLI, and web UI.
Always know, what's happening on your network
WatchGuard understands the importance of network visibility and continues to deliver excellent solutions, that help customers detect harmful activities, before they become massive problems. With WatchGuard you can pinpoint significant network activities to take immediate corrective or diagnostic actions directly from the interactive, real-time monitoring. -
Total protection
Every network needs a full arsenal of scanning engines to protect against spyware, viruses, malicious apps, data leakage, botnets and more. WatchGuard's network security platform not only provides the complete suite of unified security controls, but offers solutions for addressing evolving network threats. -
Easily deploy and manage many appliances
Distributed organizations will especially appreciate the intuitive tools, that support policy creation, management and enforcement across multiple locations. Avoid having network administrators onsite to configure remote devices with WatchGuard's zero-touch RapidDeploy feature. RapidDeploy saves time and resources on initial configuration and deployment of network security.
- WatchGuard Firebox M470 - security appliance - with 3 years Basic Security Suite
- Security appliance
- Bundled Services
- 3 years Basic Security Suite
- Form Factor
- External - 1U
- Ports Qty
- 8
- Data Link Protocol
- Performance
- Firewall throughput: 19.6 Gbps , Firewall throughput (IMIX): 5.6 Gbps , VPN throughput: 5.2 Gbps , VPN throughput (IMIX): 1.8 Gbps , HTTPS throughput: 2 Gbps , Antivirus throughput: 3.5 Gbps , IPS throughput: 5.7 Gbps , Unified Threat Management (UTM) throughput: 3.1 Gbps
- Capacity
- Concurrent connections: 3800000 , Concurrent connections (proxy): 310000 , New connections per second: 82000 , Virtual interfaces (VLANs): 300 , Authenticated users: unlimited , Branch office VPN tunnels: 250 , Mobile VPN tunnels: 250 , TDR host sensors: 250 , Priority queues: 8
- VoIP Protocols
- H.323, SIP
- Included Accessories
- Rack mount kit
- Power
- AC 120/230 V
- 42.8 cm x 32 cm x 4.4 cm
- Bundled Services
- Height (Rack Units)
- 1U
- 42.8 cm
- 32 cm
- 4.4 cm
- Form Factor
- External
- Ports Qty
- 8
- Connectivity Technology
- Wired
- TCP/IP, UDP/IP, PPPoE, SMTP, FTP, DHCP, DNS, POP3, IMAP, DDNS
- Routing Protocol
- OSPF, BGP-4, RIP-1, RIP-2, static IP routing, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 2, SNMP 3, HTTP, HTTPS, CLI
- Performance
- Capacity
- NAT support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, DiffServ support, IPv6 support, Intrusion Prevention System (IPS), Deep Packet Inspection (DPI), HTTPS proxy, anti-spam protection, Quality of Service (QoS), IPSec NAT-Traversal (NAT-T), WAN failover, DHCP server, DNS proxy, FTP proxy, HTTP proxy, POP3 proxy, SMTP proxy, DHCP relay, DHCP client, proxy firewall, WAN load balancing, Server Load Balancing (SLB), Reputation Enabled Defense, TCP/UDP proxy
- Encryption Algorithm
- DES, Triple DES, RSA, IKE, 128-bit AES, 256-bit AES, IKEv2, SHA-2
- Authentication Method
- SecurID, RADIUS, LDAP, internal user database, Active Directory, VASCO token authentication, Duo
- IEEE 802.3ad (LACP)
IP Telephony
- VoIP Protocols
- H.323, SIP
- Expansion Slots
- 1 (total) / 1 (free) x expansion slot
- 6 x 1000Base-T - RJ-45 , 2 x 1000Base-T - SFP (mini-GBIC) , 2 x USB , 1 x serial
- Rack mount kit
- MTBF
- 51,644 hours
- ICSA IPSec certified, ICSA Firewall certified, CB, CSA NRTL/C, RoHS, FIPS 140-2, WEEE, REACH, Common Criteria EAL4+, IPv6 Ready
- Voltage Required
- AC 120/230 V
- 75 Watt
- Software Included
- WatchGuard Dimension
- Shipping Width
- 55.9 cm
- Shipping Depth
- 53.3 cm
- Shipping Height
- 12.7 cm
- Shipping Weight
- 8.17 kg
- 0 °C
- 40 °C
- 5 - 90% (non-condensing)
