WatchGuard Technologies XTM 505 with 3 Yr UTM Bundle
Quicklinx: 7VHWWS00 Mfr#: WG505033
Get everything you need for complete unified threat management at a great price with the XTM 505 Security Bundle. The Bundle includes a WatchGuard XTM 505 security appliance with 850 Mbps firewall throughput, 210 Mbps VPN throughput, and 6 Gigabit Ethernet ports. In addition, the Bundle delivers a full suite of UTM security subscriptions to boost protection in critical attack areas, including Application Control, spamBlocker, Gateway AntiVirus, Reputation Enabled Defense, WebBlocker, and Intrusion Prevention Service, plus LiveSecurity Service for support and maintenance.
  • Fast 2.3 Gbps throughput
    The XTM 5 Series puts other appliances in its class to shame with up to 2.3 Gbps for firewall throughput and 800 Mbps XTM throughput, even with all security services and deep packet inspection enabled. The 5 Series delivers formidable performance for exceptional value.
  • Fireware XTM included
    The Fireware XTM OS increases security and networking capabilities. When you're ready, it's easy to upgrade to the Pro version of the OS for even more features.
  • 3 ways to manage your appliance
    Now you have the power to choose how you manage your WatchGuard appliance including, WatchGuard System Manager, the command line interface, and a web UI for access from anywhere, anytime.
  • Skype blocking
    Block Skype connections to and from protected hosts to keep productivity high and prevent malware injections and data leakage.
  • Reporting in the Browser
    Provides a web-based, customizable reports portal designed to be hosted with direct Internet access for easy report selection and viewing.
  • Remote/external log server/report server DB
    MSSPs and larger organizations can now take advantage of the ability to isolate logging and reporting on a separate PC for high performance, scalability, and redundancy.
  • Self Health monitoring
    Health monitoring for the WSM logging and reporting system helps minimize disruptions and maintain high service levels in these critical functions.
  • Green security
    The firewalls are designed with efficiency in mind, consuming very little energy. Compare the power consumption to other security products and see how WatchGuard can make your data center more energy efficient. Green up your network with WatchGuard.
  • An investment in your security
    Model upgradability ensures your network security investment is protected with the ability to easily upgrade its performance, capacity, and security capabilities as business requirements change and new threats emerge.
WatchGuard XTM 5 Series 505 - security appliance - with 3 years Gateway AV/IPS, Application Control, spamBlocker, WebBlocker, Reputation Enabled Defense, LiveSecurity Service Subscriptions
Security appliance
Bundled Services
External - 1U
Ports Qty
7
Performance
Firewall throughput: 850 Mbps
Virtual interfaces (VLANs): 75 , Concurrent sessions: 40000 , Branch office VPN tunnels: 65 , Mobile IPSec VPN tunnels: 5 , Mobile SSL VPN tunnels: 1 , Nodes (LAN IPs): unlimited
VoIP Protocols
H.323, SIP
43.2 cm x 28.6 cm x 4.4 cm
7.3 kg
1-year warranty
Security appliance
Bundled Services
Height (Rack Units)
1U
Built-in Devices
Status LCD
43.2 cm
28.6 cm
4.4 cm
7.3 kg
External
Ports Qty
7
Wired
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, PPPoE, FTP, DHCP, DNS, POP3
Routing Protocol
OSPF, BGP-4, RIP-1, RIP-2, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, SNMP 3, HTTP, HTTPS
Performance
Status Indicators
Power, status, link/activity
DHCP support, DoS attack prevention, dynamic DNS server, Quality of Service (QoS), VPN failover, DHCP server
Encryption Algorithm
DES, Triple DES, MD5, IKE, SSL, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
VASCO token authentication, XAUTH (RADIUS, LDAP, Active Directory)
IP Telephony
VoIP Protocols
H.323, SIP
1 x management - RJ-45 , 2 x management , 6 x 1000Base-T - RJ-45 , 1 x 100Base-TX - RJ-45
Rack Mounting Kit
Included
CB, CSA NRTL/C, RoHS, WEEE, EAL 4
Internal power supply
50 watt
1-year warranty
