WatchGuard Technologies X10e UTM Bundle (Includes appliance)
Quicklinx: 4Y2VWS00 Mfr#: WG50016
Firebox X10e UTM Bundle from WatchGuard has everything a small business, remote office, or telecommuter needs for robust, multi-layered security in one convenient package. Bundle includes Firebox X Edge e-Series unified threat management appliance and one-year renewable subscriptions to spamBlocker, WebBlocker, and Gateway AntiVirus/Intrusion Prevention Service, plus one year of LiveSecurity Service for expert guidance and support.
WatchGuard Firebox X Edge e-Series X10e UTM Bundle - security appliance - with 1 year Gateway AV/IPS, spamBlocker, WebBlocker, LiveSecurity Service Subscribtions
Security appliance
Bundled Services
External
1 x ARM XScale 266 MHz
RAM
128 MB
Flash Memory
64 MB
Ports Qty
6
Ethernet, Fast Ethernet
Performance
Firewall throughput: 100 Mbps , VPN throughput: 35 Mbps
Security zones: 2 , Concurrent sessions: 6000 , Nodes (LAN IPs): 15 , Branch office VPN tunnels: 5 , IPSec VPN tunnels: 1 (maximum 11) , Authenticated users (internal database): 200 , SSL VPN tunnels: 1 (maximum 11)
18.8 cm x 16.5 cm x 3.6 cm
0.8 kg
1-year warranty
Security appliance
Bundled Services
Built-in Devices
Status LCD
18.8 cm
16.5 cm
3.6 cm
0.8 kg
Processor / Memory / Storage
Processors Installed
RAM
128 MB
Flash Memory
64 MB
External
Ports Qty
6
Wired
Cable(s) / Media Type Supported
Network cable
Data Transfer Rate
100 Mbps
Network / Transport Protocol
PPTP, IPSec, PPPoE
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP
Performance
Status Indicators
Power, status, link/activity
Firewall protection, IP-routing, DHCP support, NAT support, hardware encryption, PAT support, Syslog support, Stateful Packet Inspection (SPI), packet filtering, manageable, VPN passthrough, Quality of Service (QoS), Dead Peer Detection (DPD)
Encryption Algorithm
DES, Triple DES, MD5, IKE, SSL, SHA-1
Authentication Method
LDAP, Active Directory
1 x management - DB-9 , 6 x 100Base-TX - RJ-45
1 x network cable
RoHS, WEEE
Power supply - external
12 Watt
Limited warranty - 1 year
45 °C
10 - 85%
