WatchGuard Technologies TRADE UP TO FIREBOX X1250E UTM BUNDLE
Quicklinx: 6CKKWS00 Mfr#: WG51253-T
Now WatchGuard makes it even easier for small to mid-size businesses to get comprehensive unified threat management (UTM) - the best in its class. Everything you need for robust, multi-layered security, including expert guidance and support, is bundled in one convenient package for streamlined setup and ongoing maintenance.
The Firebox X Core 1250e UTM Bundle includes Firebox X1250e firewall/VPN appliance with zero day attack protection, plus one-year subscriptions to Gateway AntiVirus/Intrusion Prevention Service with anti-spyware, spamBlocker, WebBlocker, and LiveSecurity Service for 24/7 technical support, software updates, and threat alerts.
WatchGuard Firebox X Core e-Series x1250e UTM Bundle - security appliance - with 1 year Gateway AV/IPS, spamBlocker, WebBlocker, LiveSecurity Service Subscribtions
Security appliance
Bundled Services
External - 1U
English / United States
Ports Qty
8
Performance
Firewall throughput: 1.5 Gbps , VPN throughput: 100 Mbps
Concurrent sessions: 200000 , Security zones: 8 , Nodes: unlimited , Branch office VPN tunnels: 600 , IPSec VPN tunnels: 400 , Authenticated users (internal database): 5000 , SSL VPN tunnels: 1 (upgradeable to 500)
Pricing Type
WatchGuard Firebox Trade-Up Program
42.6 cm x 36.2 cm x 4.5 cm
4.4 kg
1-year warranty
Security appliance
Bundled Services
Height (Rack Units)
1U
Built-in Devices
Status LCD, keypad
42.6 cm
36.2 cm
4.5 cm
4.4 kg
External
Ports Qty
8
Wired
Cable(s) / Media Type Supported
Network cable
Data Transfer Rate
1 Gbps
Network / Transport Protocol
TCP/IP, PPTP, IPSec, PPPoE, SMTP, FTP, DHCP
Routing Protocol
OSPF, BGP-4, RIP-1, RIP-2, static IP routing
Remote Management Protocol
SNMP, HTTP
Performance
Status Indicators
Power, status, link/activity
Firewall protection, 128-bit encryption, routing, DHCP support, NAT support, hardware encryption, VPN support, Syslog support, traffic shaping, DoS attack prevention, dynamic DNS server, manageable, E-mail alert, domain blocking, 256-bit encryption, DDos attack prevention, proxy server, SMTP traffic control, Dead Peer Detection (DPD)
Encryption Algorithm
DES, Triple DES, RSA, MD5, AES, IKE, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
SecurID, RADIUS, LDAP, Active Directory
1 x management - DB-9 , 8 x 1000Base-T - RJ-45
Rack Mounting Kit
Included
RoHS, WEEE
Pricing Type
Internal power supply
60 Watt
Limited warranty - 1 year , New releases update - 1 year
45 °C
10 - 85%
