Get everything you need for comprehensive Unified Threat Management for your small business/remote office with the Firebox X Edge e-Series UTM Bundle. An exceptional value, each package includes; Firebox X Edge e-Series appliance; Gateway AV/IPS (1 year); spamBlocker (1 year); WebBlocker (1 year); LiveSecurity Service (1 year).
From initial purchase through ongoing security management, the Firebox X Edge e-Series UTM Bundle streamlines network security management while providing powerful network protection. Buy together and save!
- WatchGuard Firebox X Edge e-Series X20e-w UTM Bundle - security appliance - Wi-Fi - with 1 year Gateway AV/IPS, spamBlocker, WebBlocker, LiveSecurity Service Subscribtions
- Security appliance
- Bundled Services
- 1 year Gateway AV/IPS, spamBlocker, WebBlocker, LiveSecurity Service Subscribtions
- Form Factor
- External
- Processor
- 1 x ARM XScale 266 MHz
- RAM
- 128 MB
- Flash Memory
- 64 MB
- Ports Qty
- 6
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
- Performance
- Firewall throughput: 100 Mbps , VPN throughput: 35 Mbps
- Capacity
- Security zones: 2 , Concurrent sessions: 8000 , Nodes (LAN IPs): 30 , Branch office VPN tunnels: 15 , Mobile user VPN tunnels: 5 , Authenticated users (internal database): 200
- Power
- AC 120/230 V (50/60 Hz)
- 26.9 cm x 16.5 cm x 18.5 cm
- 0.9 kg
- 1-year warranty
- Bundled Services
- Built-in Devices
- Status LCD
- 26.9 cm
- 16.5 cm
- 18.5 cm
- 0.9 kg
Processor / Memory / Storage
- Processors Installed
- RAM
- 128 MB
- Flash Memory
- 64 MB
- Form Factor
- External
- Ports Qty
- 6
- Connectivity Technology
- Wireless, wired
- Cable(s) / Media Type Supported
- Network cable
- PPTP, IPSec, PPPoE
- Routing Protocol
- Static IP routing
- Performance
- Capacity
- Status Indicators
- Power, status, link/activity
- Firewall protection, routing, Layer 2 switching, DHCP support, NAT support, hardware encryption, PAT support, Syslog support, Stateful Packet Inspection (SPI), VPN passthrough, URL filtering, Quality of Service (QoS)
- Encryption Algorithm
- DES, Triple DES, MD5, IKE, SHA-1
- Authentication Method
- LDAP, Active Directory
- IEEE 802.11b, IEEE 802.11g
Aerial
- Antenna Qty
- 2
- 1 x management - DB-9 , 6 x 100Base-TX - RJ-45
- Cables Included
- 1 x network cable
- RoHS
- Power Device
- External power adapter
- Voltage Required
- 12 Watt
- Limited warranty - 1 year , New releases update - 1 year
- 0 °C
- 45 °C
- 10 - 85%
