WASP Nest Wand Suite (USB connection)
Quicklinx: BF6MWS00 Mfr#: 633808390365
WaspNest Suite is a complete barcode starter solution designed for home and small office applications. This value packed suite includes a barcode scanner for reading barcodes; barcode labeling software for creating barcodes; and tracking software for simple inventory tracking and asset tracking. In addition to basic inventory tracking and asset tracking ability, WaspNest comes with a full version of WaspLabeler, which allows you to create and print asset tags and barcode labels in minutes.
WaspNest is available in four different barcode scanner options: laser barcode scanner, CCD LR barcode scanner, CCD barcode scanner and a wand/pen barcode scanner. The laser barcode scanner is the most versatile with the longest read range; the CCD LR (long range) and CCD are great for moderate use; while the wand/pen barcode scanner provides the lowest price.
WaspNest WWR2900 Pen Barcode Scanner Suite - USB - box pack - 1 user
Box pack
Category
Creativity application - labelling / barcode software
Licence Qty
1 user
Platform
Windows
Distribution Media
CD-ROM
Category
Box pack
Platform
Windows
Distribution Media
CD-ROM
Min Supported Colour Depth
32-bit colour
Licencing
Licence Qty
1 user
Supported OS
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3
Hardware Requirements
Microsoft Windows 2000 / XP - 400 MHz - RAM 512 MB - HD 400 MB , Microsoft Windows Server 2003 - 400 MHz - RAM 512 MB - HD 400 MB
Additional Requirements
CD-ROM
