WASP Nest CCD LR Suite (USB connection)
Quicklinx: BF6RWS00 Mfr#: 633808390389
WaspNest Suite is a complete barcode starter solution designed for home and small office applications. This value packed suite includes a barcode scanner for reading barcodes; barcode labeling software for creating barcodes; and tracking software for simple inventory tracking and asset tracking. In addition to basic inventory tracking and asset tracking ability, WaspNest comes with a full version of WaspLabeler, which allows you to create and print asset tags and barcode labels in minutes.
WaspNest is available in four different barcode scanner options: laser barcode scanner, CCD LR barcode scanner, CCD barcode scanner and a wand/pen barcode scanner. The laser barcode scanner is the most versatile with the longest read range; the CCD LR (long range) and CCD are great for moderate use; while the wand/pen barcode scanner provides the lowest price.
WaspNest WLR8900 CCD LR Barcode Scanner Suite - USB - box pack - 1 user
Box pack
Category
Creativity application - labelling / barcode software
Licence Qty
1 user
Platform
Windows
Distribution Media
CD-ROM
Category
Box pack
Platform
Windows
Distribution Media
CD-ROM
Min Supported Colour Depth
32-bit colour
Licencing
Licence Qty
1 user
Supported OS
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows XP (32/64 bits) SP3
Hardware Requirements
Pentium 4 - 800 MHz - RAM 1 GB - HD 2 GB
Additional Requirements
CD-ROM
