The PL-900 is the latest addition to the PL series and features a 19" screen at SXGA resolution with enhanced visual quality due to a wider viewing angle and the screen's anti-glare finish. The ergonomic cord- and batteryless PL pen allows fast data input directly on the screen with full pressure sensitivity and, thanks to the "Penabled" technology, the PL pen is compatible with a wide range of Tablet PC models. The built-in video scaler re-formats DVI signals that are in wide-screen (16:10) mode, thus squeezed images are a thing of the past on the PL-900.
- Wacom PL 900 - digitiser - USB
- Digitiser
- Connectivity Technology
- Wired - USB
- Display
- LCD display - 19" - 1280 x 1024
- 45.2 cm x 5.6 cm x 39.8 cm
- 7.1 kg
- Movement Detection Technology
- Electromagnetic
- Pressure sensitive pen, Wacom DuoSwitch, built-in 2-ports USB hub
- Cables Included
- 1 x USB cable - external , 1 x DVI cable - external , 1 x DVI-VGA cable - external
- OS Required
- Microsoft Windows XP 64-bit Edition, Microsoft Windows Vista (64-bit versions), Apple MacOS X 10.4.8 or later, Microsoft Windows Vista / XP
- Digitiser
- 45.2 cm
- 5.6 cm
- 39.8 cm
- 7.1 kg
Input Device
- Wired
- Interface
- USB
- Electromagnetic
- Pressure Levels
- 512
- Active Area
- 37.8 cm x 30.3 cm
Display
- LCD display
- Diagonal Size
- 19"
- Native Resolution
- 1280 x 1024
- Image Brightness
- 270 cd/m²
- Image Contrast Ratio
- 1300:1
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- 1 x display / video - DVI-Analogue/Digital input - 24+5 pin combined DVI , 1 x display / video - DVI-Analogue/Digital output - 24+5 pin combined DVI , 1 x USB - 4 pin USB Type A
- Cables Included
- Power adapter
- Software Included
- Drivers & Utilities
- OS Required
