Wacom Grip Pen for Intuos4 + Cintiq
Quicklinx: 76BVWS00 Mfr#: KP-501E-01
Wired / Wireless: Wireless
Compatibility: PC
£54.53 ex VAT
£65.43 inc VAT
It is the professional freehand tool and the standard pen for the Intuos4. The Grip Pen is equipped with a waisted rubberized grip area that reduces gripping power by up to 40%, relieving stress and alleviating writing fatigue.
It enables you to work even more ergonomically. The optimum weight, the perfect balance and its tilt sensitivity making it the most natural freehand tool designed for extensive use. It is the must have for professional users.
The Grip Pen is equipped with two customizable side-switches and a pressure-sensitive eraser. It includes replacement nibs. This means, you are getting four different pens in one! The Grip Pen is equipped with the double side switch and the pressure-sensitive eraser. It includes replaceable pen nibs as well as a stroke nib, a flex nib and three felt nibs. This means, you are getting four different pens in one!
Wacom Grip Pen - active stylus
Active stylus
15.7 cm x 1.5 cm x 1.5 cm
18 g
Eraser, pressure sensitivity, tilt sensitive
Cintiq 21UX; Intuos4 Large, Medium, Small, Wireless, X-Large
Active stylus
15.7 cm
1.5 cm
1.5 cm
18 g
Input Device
Pressure Levels
2048
Pen stand, nibs (4 pcs.)
Wacom Cintiq 21UX , Wacom Intuos4 Large, Medium, Small, Wireless, X-Large
Compatibility: PC
Brand: Wacom
