The Wacom Intuos Pro pen tablet combines Wacom's fine pen capabilities and intuitive multi-touch gestures. It gives you the power to produce professional results with the precision and control you demand from your professional software. Designed for creative work, it delivers a natural and intuitive experience that extends your creative capabilities.
Get the most from your creative software with your favorite pre-selected shortcuts. The Intuos Pro even detects the software you're using and offers optimal selections. Quickly access all your shortcuts through the customizable ExpressKeys and touch ring. Stay focused with the express view display and radial menu. Discover intuitive navigation at the touch of your fingers: pan, zoom, rotate and navigate naturally with gestures, or create your own multi-touch shortcuts.
Designed for creativity - just the right tools
The Wacom Intuos Pro pen tablet combines Wacom's fine pen capabilities and intuitive multi-touch gestures. It gives you the power to produce professional results with the precision and control you demand from your professional software. Designed for creative work, it delivers a natural and intuitive experience that extends your creative capabilities. -
Your endless creative toolbox
2048 levels of pen pressure sensitivity and tilt recognition let you create with the accuracy and precision of traditional brushes, pens and markers, while multi-touch gestures allow you to position and navigate your work intuitively. -
Stay focused and enjoy the creative experience
Get the most from your creative software with your favorite pre-selected shortcuts. The Intuos Pro even detects the software you're using and offers optimal selections. Quickly access all your shortcuts through the customizable ExpressKeys and touch ring. Stay focused with the express view display and radial menu. Discover intuitive navigation at the touch of your fingers: pan, zoom, rotate and navigate naturally with gestures, or create your own multi-touch shortcuts. -
Enjoy wireless flexibility and ergonomics
Cut down on cord clutter and enjoy the freedom of creating wirelessly. Intuos Pro is designed ergonomically for both right and left hand use, so you'll be comfortable all day. -
Creative breathing room
The generous workspace is designed to accommodate artistic styles that require a full-range of motion and creative professionals who work in large formats.
- Wacom Intuos Pro Large - digitiser - USB - black
- Digitiser
- Connectivity Technology
- Wireless, wired - USB
- Black
- Orientation
- Right and left-handed
- 48.7 cm x 31.8 cm x 1.2 cm
- 1.8 kg
- Localisation
- English, Spanish
- Movement Detection Technology
- Electromagnetic
- Buttons Qty
- 8
- Movement Resolution
- 5080 lpi
- Programmable buttons, finger-sensitive Touch Ring, soft rubber grip, multi-touch digitiser, ExpressKeys, -/+ 60 levels tilt recognition
- Cables Included
- 1 x USB cable - 2 m
- OS Required
- Microsoft Windows Vista SP2, Microsoft Windows 7 SP1, Apple MacOS X 10.6.8 or later, Windows 8
- Digitiser
- Orientation
- 48.7 cm
- 31.8 cm
- 1.2 cm
- 1.8 kg
- Black
- Localisation
- English, Spanish
Input Device
- Wireless, wired
- Interface
- USB
- Electromagnetic
- Buttons Qty
- 8
- 5080 lpi
- Pressure Levels
- 2048
- Active Area
- 32.5 cm x 20.3 cm
- 1 x USB - 4 pin USB Type A
- Included Accessories
- Pen stand, nib removal tool, nibs (10 pcs.), colour identification rings, stylus pen
- Cables Included
- Software Included
- Drivers & Utilities
- OS Required
