The medium Intuos4 tablet is the most popular and versatile choice among creative professionals. With 48.5 square inches of working area, this tablet provides ample workspace for most tablet users.
The medium size is built with eight ExpressKeys and illuminated displays that provide easy reference to your assigned functions.
- Wacom Intuos4 M - digitiser - USB
- Digitiser
- Connectivity Technology
- Wired - USB
- 37 cm x 25.4 cm x 1.2 cm
- 1 kg
- Localisation
- English
- Movement Detection Technology
- Electromagnetic
- Movement Resolution
- 5080 lpi
- Accuracy
- ± 0.25 mm
- Programmable buttons, eraser, finger-sensitive Touch Ring, 8 ExpressKeys, tilt sensitive
- Cables Included
- 1 x USB cable - 1.5 m
- OS Required
- Microsoft Windows XP SP2, Microsoft Windows Vista, Apple MacOS X 10.4.8 or later
- Microsoft Certification
- Compatible with Windows 7
- 2-year warranty
- Digitiser
- 37 cm
- 25.4 cm
- 1.2 cm
- 1 kg
- Localisation
- English
Input Device
- Wired
- Interface
- USB
- Electromagnetic
- 5080 lpi
- Accuracy
- ± 0.25 mm
- Pressure Levels
- 2048
- Active Area
- 14 cm x 22.4 cm
- 1 x USB - 4 pin USB Type A
- Included Accessories
- Pen stand, nibs (10 pcs.)
- Cables Included
- FCC Class B certified, VCCI Class B ITE
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years
