The DTK-2241 combines a 21.5", 16:9 widescreen LCD with Wacom's patented, cordless, battery-free pen technology and 5 user-assignable ExpressKeys.
The DTK-2241 interactive pen display is a premium communication tool. The impressive 21.5" LCD with high resolution and wide viewing angle provides a large screen for users to work on. It is optimal for streamlining the electronic documents workflow within education, healthcare and business settings. Mark up and annotate presentations or lesson plans for interactive teaching; complete electronic forms using digital ink; and capture signatures directly in documents. Five customizable ExpressKeys provide additional convenience by offering easy access to shortcuts and commonly used functions.
- Wacom DTK-2241 - digitiser - USB
- Digitiser
- Connectivity Technology
- Wireless - USB
- Display
- LCD display - 21.5" - 1920 x 1080
- 56.6 cm x 38.5 cm x 5.5 cm
- 6.55 kg
- Movement Detection Technology
- Electromagnetic
- Accuracy
- ± 0.5 mm
- Pressure sensitive pen, eraser, built-in 2-ports USB hub
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Vista SP2, Microsoft Windows XP SP3, Microsoft Windows 7 SP1 or later, Apple MacOS X 10.6.8 or later, Windows 8, Windows 8 64-bit Edition
- Digitiser
- 56.6 cm
- 38.5 cm
- 5.5 cm
- 6.55 kg
Input Device
- Wireless
- Interface
- USB
- Electromagnetic
- Accuracy
- ± 0.5 mm
- Pressure Levels
- 1024
- Active Area
- 47.52 cm x 26.73 cm
Display
- LCD display
- Diagonal Size
- 21.5"
- Pixel Pitch
- 0.2475 mm
- Colour Support
- 16.7 million colours
- Native Resolution
- 1920 x 1080
- Image Brightness
- 210 cd/m²
- Image Contrast Ratio
- 900:1
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Response Time
- 14 ms
- 2 x USB - 4 pin USB Type A , 1 x display / video - DVI-Analog/Digital - 24+5 pin combined DVI
- RoHS, J-MOSS, VCCI Class B
- Power adapter
- Software Included
- Drivers & Utilities
- OS Required
