Wacom Cintiq 27" QHD Touch (Pen & Touch Input) Graphics Display
Quicklinx: B244WS00 Mfr#: DTH-2700
The Cintiq 27QHD Touch creative pen displays set a new standard in color and resolution. The most natural form of creative expression meets an advanced interface design that re-imagines the creative workflow so you don't have to adapt to the tool - the tool adapts to you. Work with hands-on fluidity as you create with a pressure-sensitive pen and multi-touch gestures directly on an expansive, edgeless glass display.
The Cintiq 27QHD's 27" widescreen 16:9 display offers the highest resolution of any Cintiq (2560 x 1440). Featuring 97% Adobe RGB, 1.07 billion colors and REC 709, this premium color display is the ultimate tool for color sensitive workflows.
The Cintiq 27QHD Touch allows you to immerse yourself in your work by using Multi-Touch gestures in applications such as Photoshop and Adobe Illustrator CC to position and navigate your work with one hand while you create with the pressure-sensitive pen in the other.
The ExpressKey Remote can be positioned anywhere on the screen for a faster, more flexible workflow. Customize the ExpressKeys on the remote with your favorite shortcuts, and use the Touch Ring to zoom, rotate or change brush sizes. Spend less time searching for the correct shortcut and more time getting lost in your ideas.
Choose your working position and stand: place the Cintiq 27QHD Touch on your desk for either a 5° slope or foldout the sturdy legs for a 20° angle.
The Cintiq 27QHD Touch Pro Pen features Wacom's proprietary Tip Sensor technology, which offers users near-zero (one gram) starting pressure and virtually the same natural experience as one working with traditional brushes or pens. The pen also features a pressure-sensitive eraser and two side switches that can be customized for common commands, such as double-click and right-click. The pen includes 2048 levels of pressure sensitivity and 40° pen tilt recognition.
Compatible with both Mac and PC platforms, the Cintiq 27QHD works seamlessly with your computer's configuration, including another Cintiq, an Intuos pen tablet, or your existing mouse.
  • It takes millions of pixels to make colors look this sharp
    The Cintiq 27QHD offers true-to-life color on a high-resolution display giving you unparalleled clarity and color sensitivity in creative areas like image editing and 3D animation. A widescreen 16:9 display with four times the pixel density of standard HDTV gives you the resolution (2560 x 1440) to handle the finest detail. Experience limitless possibility with 97% Adobe RGB, 1.07 billion colors and REC 709 for frame-to-frame color matching. It's a whole definition of "exact" in color management.
  • Spend more time creating
    The ExpressKey Remote encourages a faster, more flexible workflow with a Touch Ring that helps you scroll, zoom and rotate with ease. Put it on the screen, beside your keyboard or right in your hand. Spend less time searching for what you need and more time getting lost in your ideas.
Wacom Cintiq 27QHD Touch - digitiser - USB - black
Digitiser
Wired - USB
Display
LCD display - 27" - 2560 x 1440
77 cm x 46.5 cm x 5.45 cm
9 kg
Canada, United States
Multi-Touch
Pressure sensitive pen, eraser, finger-sensitive Touch Ring, tilt sensitive, ExpressKeys, adjustable stand
AC 120/230 V
Microsoft Windows 7 or later, Apple MacOS X 10.8 or later
Digitiser
77 cm
46.5 cm
5.45 cm
9 kg
Input Device
Wired
USB
Multi-Touch
Pressure Levels
2048
Active Area
51.84 cm x 32.4 cm
Display
LCD display
Diagonal Size
27"
Image Aspect Ratio
16:9
Colour Support
1.07 billion colours
Native Resolution
2560 x 1440
1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - DisplayPort - 20 pin DisplayPort , 4 x SuperSpeed USB 3.0 - 9 pin USB Type A
Pen stand, stand, nibs (10 pcs.), remote control, USB cable, AC power adapter, Mini DisplayPort to DisplayPort adapter, DVI-D to HDMI Cable adapter, DisplayPort cable, HDMI cable
AC 120/230 V
Software Included
Drivers & Utilities
