Vision TM-IFP Flat Panel Floor Stand
Quicklinx: 9K6QWS00 Mfr#: TM-IFP
Robust and simple, the Techmount for flat-panels fits any flat-panel LCD or LED screen which uses VESA mounting points up to 600 wide x 400 mm tall apart.
The TM-IFP features a dynamic cable management system which uses retracting reels to help avoid the power and input cables dropping into sight when the flat-panel is lowered.
  • Cable retraction
  • Remote control
    A simple cable remote control fits to the rear of the flat panel out of reach from little fingers.
  • Wall anchors
    A stand-off bracket fixes the column to the wall and allows dado rail to pass behind the assembly.
  • Shared power
    An integrated power output means the flat-panel and mount can share a single power cable.
  • Rear cubby
    Accommodation for cable-tying power distribution block or media player at rear.
  • Hang and lock
    With the VESA plates attached to the flat-panel the screen assembly simply lowered on to the upper column and bolts lock it in place.
  • Cable management
    An aluminum cable trunking strip on the lower part of the column hides cables.
  • Leveling floorplate
    An adjustable floor plate allows for floors which are not flat or level.
Vision Techconnect TM-IFP stand - for flat panel
Stand - floor-standing
Recommended Use
Flat panel
VESA Mounting Interface
400 x 600 mm
Max Load Weight
115 kg
AV Furniture
Stand
Recommended Use
Flat panel
Placing / Mounting
Floor-standing
400 x 600 mm
Cable Management
Integrated cable management
Max Load Weight
115 kg
Adjustable height, motorised, remote control
