The Techmount TM-CC is a universal projector ceiling bracket designed to secure 99% of data projectors safety and sturdily to ceilings. It is designed for applications where no 'drop' is required so no pole is included.
Robust construction
High standard of finish and over-engineered for stability and safety. A rugged high-quality satin-white finish blends with ceiling tiles. -
Maneuverable
The top and bottom parts can rotate 360 degrees, and the spider arms have a maximum span of 340mm. -
Sloping ceilings
A tilting mechanism is built in allowing you to use the bracket with cathedral-type ceilings. -
Safety approved
The TM-CC has a recommended maximum safe working load (SWL) of 10kg which is well within the limits of the product.
- Vision Techmount TM-CC mounting kit - for projector - satin white
- Product Type
- Mounting kit
- Recommended Use
- Projector
- Max Load Weight
- 10 kg
- Satin white
- Limited lifetime warranty
- Satin white
AV Furniture
- Mounting kit
- Recommended Use
- Projector
- Max Load Weight
- 10 kg
