The TM-CAGE is obvious enough to serve as an effective visual deterrent, but is unobtrusive. Just because it needs to be seen, doesn't mean it needs to be ugly! The enclosure assembles like a puzzle making it deceptively difficult to take apart.
The cage conforms as closely as possible to the size of the projector, which allows a more secure design and makes it more attractive. Security is enhanced because the projector can't be maneuvered within the enclosure to squeeze it out of an aperture, and also an attempt to cut the cage would almost certainly damage the projector.
Lightweight
The TM-CAGE is obvious enough to serve as an effective visual deterrent, but is unobtrusive. Just because it needs to be seen, doesn't mean it needs to be ugly! The enclosure assembles like a puzzle making it deceptively difficult to take apart. -
Close-fitting
The cage conforms as closely as possible to the size of the projector, which allows a more secure design and makes it more attractive. Security is enhanced because the projector can't be maneuvered within the enclosure to squeeze it out of an aperture, and also an attempt to cut the cage would almost certainly damage the projector. -
Vibration resistant
The projector sits upside-down inside the cage on high density foam blocks which provide damping from vibration and protect the chassis of the projector.
- Vision Techmount TM-CAGEM - projector security kit
- Product Type
- Projector security kit
- Package Content
- 2 x keys, 2 medium plates, 2 disk locks, 16 x foam blocks, 2 access prevention collars, hex key
- Satin white
- Product Material
- Steel
- 2-year warranty
- Product Type
- Package Content
- Product Material
- Steel
- Satin white
- Limited warranty - 2 years
