Vision Techconnect TC2-CTL3 Control - Wall module remote control - 6 buttons - cable/infrared
Quicklinx: 91V0WS00 Mfr#: TC2-CTL3
Vision TC2-CTL3 Techconnect In 1 AV Control System is the most flexible professional AV control device available.
A simple yet elegant and very flexible control panel device the TC2-CTL3 can control just about anything and everything that has an IR receiver or RS-232 Control including Projectors, Projector screens, TVs, DVDs and Amplifiers and just about any other type of devices that can be operated by Infra-Red or RS-232 control and will only presents users with the functions they need or use every day. No tech support calls, No losing remote controls and all in a secure wall mounted unit.
Remotes are all too often lost, stolen or just simply mislaid and in most instances a manufactures replacement remote is not all ways readily available, cheap or easy to find which often results in the equipment not been used. Installing a Vision Techconnect TC2-CTL3 can resolves all these problems.
  • Simple programming mode
    Hold down the two bottom buttons on the TC2-CTL3 to put Control into learn mode, point the original device remote at the front of the Control, and program one code per button. "Off" is pre-set to send the code twice for projectors, and the bottom buttons send codes repeatedly when held down.
  • Advanced programming mode
    Connect the TC2-CTL3 directly to a PC and use included software to allocate multiple RS-232, IR, and 12v triggers to each button. Commands for each button can be sent simultaneously, sequentially, or repeatedly if you hold the button down.
Vision Techconnect TC2-CTL3 Control wall module remote control - white
Enclosure Colour
White
4.2 cm x 3.1 cm x 7.1 cm
63 g
Cable/infrared
Supported Devices
Projector
Input Device
Keypad
Buttons Qty
6 buttons
2
4.2 cm
3.1 cm
7.1 cm
63 g
Enclosure Colour
White
Enclosure Material
Plastic
Cable/infrared
Supported Devices
Projector
Input Device
Keypad
Buttons Qty
6 buttons
Programmable, learning, back-lit buttons
Connector Type
1 x serial
1 x remote control cable - external - 10 m
Power adapter, buttons, labels, 2 IR Blasters, remote control cable
2
