ViewSonic VX2457-MHD 23.6" 2ms VGA HDMI DisplayPort LED Monitor
Quicklinx: CJ1NWS00 Mfr#: VX2457-MHD
Diagonal Size: 23.6in
Response Time: 2ms
Interfaces: DisplayPort, HDMI, VGA
£114.08 ex VAT
£136.89 inc VAT
The ViewSonic® VX2457-mhd is a 24" (23.6" viewable) Full HD price-performance monitor built for gaming and entertainment. Equipped with VESA Adaptive-Sync Technology, this monitor’s variable refresh rate capabilities virtually eliminate screen tearing and stuttering for fluid game play during fast-paced action scenes. An ultra-fast 1ms response time and low input lag mode also provides smooth screen performance free from blurring or ghosting. For a game winning competitive edge, a Game Mode hot key optimizes gameplay for FPS, RTS and MOBA. On top of that, a black stabilization function helps you target enemies lurking in the dark, while enabling the monitor to maintain brilliantly rich colors and contrast for total immersion. Flexible connectivity options such as DisplayPort, HDMI, and VGA allow you to connect to your dedicated graphics card and gaming console. The VX2457-mhd features all the perks needed to dominate all your gaming and entertainment quests.
ViewSonic LED monitor
LED-backlit LCD monitor
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1920 x 1080
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Tilt
Environmental Standards
ENERGY STAR Qualified
Display Type
Panel Type
TN
Aspect Ratio
Widescreen - 16:9
Native Resolution
1920 x 1080
- with stand
Audio
Speakers
Mechanical
Tilt
AC 120/230 V ( 50/60 Hz )
Response Time: 2ms
Interfaces: HDMI
Interfaces: VGA
Brand: ViewSonic
