Peerless-AV Dual Arm Desktop Mount for Twin 12-30 INCH Monitors
Quicklinx: 85M4WS00 Mfr#: LCT620AD
Type: Mounting kit
£196.05 ex VAT
£235.26 inc VAT
Increase productivity by freeing up desk space with more efficient display positioning. The 620AD series is a dual display Full-Motion Plus Wall Mount, and includes a grommet and desktop clamp mount solution. Installation is quick and easy, and secures a display with a quick release mechanism. Instantly set the height of the displays by raising or lowering 12.6", extending up to 22", and tilting forward and back. Furthermore, the LCT620AD can pan and rotate for a comfortable portrait or landscape viewing.
  • Effortless adjustment
    With its adjustable height, tilt and swivel design, and the ability to switch from portrait to landscape movement, the Peerless 620AD Series Desktop Mount offers flexibility. This ensures an optimal viewing experience, whether for work or entertainment.
  • Seamless integration
    The integrated cable management system keeps your workspace neat and organized by hiding wires and cables. This feature, combined with the sleek design of the mount, enhances the overall aesthetic of your desktop setup.
  • Versatile compatibility
    Designed to support two LCD displays ranging from 12"-30" (30.5-76.2 cm), and compatible with flat panel mount interfaces of 100 x 100 mm and 75 x 75 mm, this mounting kit is a versatile solution for a wide range of display needs.
  • Easy installation
    Featuring a quick release mechanism, desk clamp mount, grommet mount, and dual articulating arm, the LCT620AD model ensures a hassle-free setup. This allows for a swift and secure installation on any desktop or table mount situation.
Peerless 620AD Series Desktop Mount LCT620AD mounting kit - Tilt & Swivel - for 2 LCD displays - black
Mounting kit (Tilt & Swivel) - desktop
Recommended Use
2 LCD displays
Recommended Display Size
12"-30"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
AV Furniture
Mounting kit
Design
Tilt & Swivel
Recommended Use
2 LCD displays
Placing / Mounting
Desktop
Cable Management
Integrated cable management
12"-30"
Adjustable height, quick release, portrait to landscape movement
Type: Mounting kit
Brand: Peerless-AV
