The ViewSonic PJ-WMK-401 wall mount kit is specifically designed for ultra short throw projectors. This customizable wall mount delivers increased installation flexibility, allowing you to easily mount an ultra short throw projector in nearly any room.
- ViewSonic mounting kit - for projector - silver black
- Product Type
- Mounting kit - wall-mountable
- 28.3 cm 21.5 cm
- Adjustable Depth
- 52-95.5 cm
- Adjustments
- Tilt
- 3.61 kg
- Recommended Use
- Projector
- Max Load Weight
- 12 kg
- Material
- Plastic, steel, aluminium alloy
- Silver black
- Designed For
- ViewSonic PJD8333s, PJD8353S, PJD8633ws, PJD8653WS
- 28.3 cm
- 21.5 cm
- Adjustable Depth
- 52-95.5 cm
- 3.61 kg
- Material
- Silver black
AV Furniture
- Mounting kit
- Recommended Use
- Projector
- Placing / Mounting
- Wall-mountable
- Adjustments
- Tilt
- Max Load Weight
- 12 kg
- Swivel adjustment, lateral shift
- Designed For
