ViewSonic PJD6345 DLP XGA 3500 Lumens Projector
Quicklinx: 8N51WS00 Mfr#: PJD6345
The ViewSonic PJD6345 is an advanced networkable XGA DLP projector for classroom and corporate LAN environments. The projector is equipped with Crestron LAN controller, making it easy for IT admin to control and manage the projector from their workstations. With AMX Device Discovery certified, it's robust for any size of campus or enterprise. In addition, the PJD6345 is packed with advanced features like wired and wireless LAN display, mobile app for smart phones and tablets, USB display and PC-less presentation. Built with BrilliantColor technology, this projector produces vibrant colors, while 3500 ANSI lumens and 15000:1 contrast ratio deliver stunning razor-sharp images. The PJD6345 comes standard with HDMI and integrated speaker. A filter-less design and DynamicEco - reduce brightness by 70% when it's not in use - provide for product reliability and virtually zero maintenance. The PJD6345 advanced networkable XGA projector is ideal for use in both classroom and corporate settings.
  • Bright in classroom and conference room
    Packed with 3500 lumens and a high contrast ratio of 15,000:1 (with DynamicEco), the PJD6345 is guaranteed to shine bright - even in large classrooms and meeting rooms.
  • PC-less presentation
    Jump start your presentation without waiting for the PC to boot up. With a PC-less presentation feature, you can display MS Office documents, PDFs, videos or images directly from a USB flash drive.
  • Wireless and wired LAN display
    With its advanced networking capability, the projector can project images via wireless, or wired, LAN. The LAN display offers a quad split screen for simultaneously projecting content from up to 4 PCs, with the ability to broadcast from up to 8 projectors.
  • Plug and Play USB display
    Project your presentations using a quick and simple Plug-and-Play USB connection without running a bulky VGA cable. Plug and Play also features automatic resolution detection for excellent imaging experience.
  • 3D Blu-ray ready HDMI
    HDMI delivers high picture and sound quality without degradation. Equipped with the HDMI, ViewSonic's PJD6345 projector can display 3D images directly from 3D Blu-ray players - perfect for connecting to any HDMI-enabled devices such as PCs, laptops, tablets, and media players.
  • Superior color performance
    BrilliantColor technology provides multi-color processing to produce stunning, vibrant colors. Unlike other technologies that use just 3 primary colors to produce the image (such as LCD), the PJD6345 uses up to 5 separate colors. The sophisticated 5-segment color wheel enhances the yellow color performance that is key to accurate and vivid color reproduction. With multi-color processing, colors are richer and more vibrant with exquisite and precise detail.
ViewSonic PJD6345 - DLP projector - 3D - LAN
DLP projector
3D Capable
Brightness
3500 lumens
Contrast Ratio
15000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
240 Watt
Bulb life cycle
Up to 3500 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC), LAN
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
305 Watt
29.4 cm x 21.9 cm x 11.3 cm
2.1 kg
DLP projector
3D Capable
Ethernet
Projector
Brightness
3500 lumens
Contrast Ratio
15000:1 (dynamic)
Image Size
70 cm - 762 cm
Projection Distance
1.2 m - 13.2 m
Throw Ratio
1.97 - 2.17:1
Resolution
XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 100 kHz
Bulb type
240 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
5-segment colour wheel, BrilliantColor, USB host function, DLP 3D Ready, Crestron RoomView, AMX Device Discovery, DynamicEco Mode
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Type
Digital
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone 3.5 mm , 1 x microphone - mini-phone 3.5 mm , 1 x audio line-out - mini-phone 3.5 mm , 1 x remote control - 9 pin D-Sub (DB-9) , 1 x network - RJ-45 , 1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x USB - mini-USB Type B
Wireless remote control
1 x VGA cable
Security Features
FCC Class B certified, UL, C-Tick, cUL, NOM, SASO, CB, CCC, PSB, RoHS, WEEE, GOST-R, REACH, UkrSEPRO, KC, ERP
305 Watt
Power Consumption Operational (Standby)
0.5 Watt
Software Included
ViewSonic Wizard
29.4 cm
21.9 cm
11.3 cm
2.1 kg
10 - 90% (non-condensing)
Sound Emission
34 dB
32 dB
