Your basket is empty
ViewSonic PJD5555W WXGA 3300 Lumens Projector
Quicklinx: B2GLWS00 Mfr#: PJD5555w
Brightness: 3300ANSI lumens
Portability: Portable
12 in stock
£327.42 ex VAT
£392.90 inc VAT
The LightStream PJD5555w makes a big statement with its elegant style, widescreen display and audiovisual performance. Its curvaceous design, which includes a tactile keypad and non-slip foot pads, also presents an intuitive and user-friendly interface. Exclusive SuperColor and SonicExpert technologies provide some of the great visual and audio performance in their class. The PJD5555w boasts HDMI connectivity for convenient single-cable transfer of image & sound from numerous HD devices. High resolution 16:10 WXGA also ensures widescreen content can be displayed without any image distortion. The 3,200-lumen lamp with a 15,000:1 contrast ratio, delivering clear and bright images for small to medium meeting rooms or classrooms. Supporting 2 x VGA, Composite Video, S-Video, and 1 x VGA output, as well as Audio in/out, Mini USB and RS232, this projector has flexible connectivity with analog-based equipment. DynamicEco further reduces power consumption and extends the lamp life.
ViewSonic LightStream PJD5555W DLP projector - 3D
DLP projector - High Definition 720p
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Europe
Microdisplay
DMD Chip
Contrast Ratio
2400:1 / 15000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
190 Watt
Bulb life cycle
Up to 5000 hour(s) / up to 10000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
265 Watt
31.6 cm x 22.8 cm x 10.37 cm
2.2 kg
DLP projector - HD 720p
3D Capable
Built-in Devices
Speaker
Europe
Projector
Microdisplay
DMD Chip
Brightness
3200 lumens
Brightness (Reduced)
2560 lumens
Contrast Ratio
Image Size
76.2 cm - 762 cm
Projection Distance
1 m - 8 m
Throw Ratio
1.5 - 1.65:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
190 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
DLP 3D Ready, ViewMatch, Super Color, Dynamic Mode, DynamicEco Mode, Auto Power Off, auto power on, SonicExpert
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x audio line-in - mini-phone mono 3.5 mm , 1 x audio line-out - mini-phone mono 3.5 mm , 1 x USB - mini-USB Type B , 1 x HDMI input - 19 pin HDMI Type A
Wireless remote control
1 x VGA cable - 1.8 m
Security Features
UL, TUV GS, C-Tick, cUL, ICES-003, SASO, TUV S, CB, CCC, EMC, DOC, PSB, FCC, RoHS, KCC, WEEE, REACH, UkrSEPRO, KC, ERP, EAC, SVHC, CoC
Power Source
AC
Nominal Voltage
265 Watt
Power Consumption Stand by
0.5 Watt
Software Included
ViewSonic Wizard
31.6 cm
22.8 cm
10.37 cm
2.2 kg
10 - 90% (non-condensing)
Sound Emission
34 dB
29 dB
Brand: ViewSonic
Price Range Ex VAT: 300 - 500
