ViewSonic PJD5555LW WXGA 3100 Lumens Projector
Quicklinx: BCYSWS00 Mfr#: PJD5555LW
The ViewSonic LightStream PJD5555LW price-performance projector features 3,100 lumens, native WXGA 1280 x 800 resolution, intuitive, user-friendly design and a sleek white color chassis. SuperColor 6-Segment Color Wheel maximizes color saturation and brightness for true-to-life image projection, while SonicExpert technology delivers improved sound quality. The PJD5555LW also features connectivity including two input ports, HDMI and VGA, and a RS232 control port. An energy-saving DynamicEco feature reduces power consumption by up to 70%, and extends the lamp life. With advanced audiovisual features, flexible connectivity options, and an affordable price, the PJD5555LW is ideal for use in education and small business environments.
  • 3LCD projectors distance match
    With a throw ratio ranging from 1.49 to 1.79, this projector is primed to replace typical 3LCD projectors (EPSON, NEC, Hitachi, Panasonic, Sony) without having to move or re-install existing ceiling mounts. Also equipped with a 1.2x optical zoom lens, this projector provides mounting flexibility with a wider throw distance range.
  • Widescreen brilliance
    With high resolution 16:10 WXGA (1280 x 800) display, this projector is the affordable solution for modern day widescreen devices. Whether connecting it to a widescreen notebook in the conference room, or watching 720P HD content in the classroom, distortion-free images with matching aspect ratio are guaranteed. It is also backward compatible with 4:3 content.
  • HDMI for one-cable connectivity to HD devices
    The best and easiest way to connect to most modern HD devices is through an HDMI (High Definition Media Interface) cable. HDMI carries both video and sound thus limiting the requirement to attach an additional audio cable.
  • SuperColor
    ViewSonic's exclusive SuperColor Technology offers a wider color range than conventional projectors for true-to-life color performance in any light. SuperColor 6-Segment Color Wheel maximizes brightness with the highest color saturation over others in the same class.
  • SonicExpert clear, comfortable and louder sound
    Following groundbreaking and exclusive speaker developments - transducer and chamber re-design - LightStream projectors deliver superior audio performance than competitor projectors. The compact yet powerful speakers sound stronger and enable sound to travel further, powerful enough to fill your meeting room with wall-to-wall sound.
  • Bright images for any environment
    Packed with 3,100 lumens the PJD5555Lw is guaranteed to produce bright images in any environment - even in rooms with high ambient light. The impressive 18,000:1 contrast ratio also ensures that dark and bright areas are more black and white and less gray in appearance.
  • Easy-of-use pre-set color modes
    Providing 5 pre-set color modes, users can choose the best one to suit their material. These 5 modes are: Brightest Mode for environments where extra-high brightness is required; Dynamic Mode for presentations with a lot of text; Standard Mode for matching PC or notebook color; ViewMatch Mode for general viewing; Movie Mode for watching movies with better saturation in a dark environments.
ViewSonic LightStream PJD5555Lw - DLP projector - 3D - white
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
White
Built-in Devices
Speaker
Europe
Brightness
3100 ANSI lumens
Contrast Ratio
18000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
Component video
Speakers
Speaker(s) - integrated
265 Watt
36.2 cm x 23.1 cm x 10.9 cm
2.4 kg
3D Capable
Built-in Devices
Speaker
Enclosure Colour
White
Europe
Projector
Brightness
3100 ANSI lumens
Contrast Ratio
18000:1 (dynamic)
Image Size
76.2 cm - 762 cm
Throw Ratio
1.49 - 1.79:1
Digital Zoom Factor
2x
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
120 Hz
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean, Indic (Indian Languages)
DLP 3D Ready, Super Color, DynamicEco Mode, Auto Power Off, Presentation Timer, auto power on, sleep timer, My Button
Lens
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Analogue video Signal
Component video
Video Interfaces
VGA, HDMI
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - mini-USB Type B , 1 x HDMI input - 19 pin HDMI Type A
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar, keypad lock
Power Source
AC
265 Watt
Power Consumption Stand by
0.5 Watt
36.2 cm
23.1 cm
10.9 cm
2.4 kg
Sound Emission
32 dB
28 dB
