ViewSonic PJD5550LWS WXGA 1200x800 3000 Lumens Projector
Quicklinx: BBCZWS00 Mfr#: PJD5550LWS
The ViewSonic LightStream PJD5550LWS price-performance short throw projector features 3,200 lumens, native WXGA 1280 x 800 resolution, user-friendly design, and a sleek white chassis. Exclusive SuperColor 6-Segment Color Wheel maximizes color saturation and brightness for true-to-life image projection, while SonicExpert technology delivers improved sound quality. A short throw lens with a 0.5 throw ratio offers large projection images for smaller rooms. The PJD5255L also features HDMI and VGA connectivity, and a RS232 control port. An energy-saving DynamicEco feature reduces power consumption by up to 70%, and extends the long lamp life. With advanced audiovisual features, flexible connectivity, and an affordable price, the PJD5550LWS is ideal for use in education and small business environments.
  • SuperColor: best in class color accuracy
    ViewSonic's proprietary SuperColor technology offers a wider color range than conventional DLP projectors for true-to-life color performance in any light. SuperColor 6-segment color wheel maximizes brightness Increased by 15% or more with the highest color saturation over others in the same class.
  • Widescreen brilliance
    With native 1280 x 800 (WXGA) resolution, the wide-format projector offers a tremendous degree of flexibility and compatibility. Whether connecting it to a widescreen notebook in the conference room, or watching 720P HD content in the classroom, distortion-free images with matching aspect ratio are guaranteed. Besides, it is also compatible with other common display resolutions.
  • Short throw lens for large projections in small places
    The short throw lens enables large images to be projected from short distances in small rooms. This means there are no distracting shadows on the projected image, and no blinding lights in the eyes of presenters.
  • 3D Blu-ray ready HDMI
    Equipped with the HDMI, this projector can display 3D images directly from 3D Blu-ray players - perfect for connecting to any HDMI-enabled devices such as PCs, laptops, tablets, and media players.
ViewSonic LightStream PJD5550LWS - DLP projector - short-throw - 3D - white
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
White
Built-in Devices
Speaker
Europe
Brightness
3300 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Lens
Short-throw fixed lens
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
Component video
Speakers
Speaker(s) - integrated
275 Watt
36.2 cm x 24.8 cm x 11.6 cm
2.5 kg
3D Capable
Built-in Devices
Speaker
Enclosure Colour
White
Europe
Projector
Brightness
3300 ANSI lumens
Contrast Ratio
20000:1 (dynamic)
Image Size
76.2 cm - 762 cm
Throw Ratio
0.50:1
Digital Zoom Factor
2x
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Max Sync Rate (V x H)
144 Hz
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean, Indic (Indian Languages)
6-segment colour wheel, Super Color, DynamicEco Mode, Presentation Timer, sleep timer, SonicExpert
Lens
Zoom Type
Manual
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Analogue video Signal
Component video
Video Interfaces
VGA, HDMI
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - mini-USB Type B , 1 x HDMI input - 19 pin HDMI Type A
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection, security bar, keypad lock
Power Source
AC
275 Watt
Power Consumption Stand by
0.5 Watt
36.2 cm
24.8 cm
11.6 cm
2.5 kg
Sound Emission
32 dB
28 dB
